Nikolay Milkov Posted January 29, 2012 Posted January 29, 2012 When I try to mount a install.wim using All-In-One tool it shows me that an unhandled exception has occured in my application:See the end of this message for details on invokingjust-in-time (JIT) debugging instead of this dialog box.************** Exception Text **************System.NullReferenceException: Object reference not set to an instance of an object. at System.Windows.Forms.ListView.CheckedIndexCollection.get_Count() at System.Windows.Forms.ListView.CheckedListViewItemCollection.get_Count() at W7T.frmAllInOne.lstOptions_ItemChecked(Object sender, ItemCheckedEventArgs e) at System.Windows.Forms.ListView.OnItemChecked(ItemCheckedEventArgs e) at System.Windows.Forms.ListView.WmReflectNotify(Message& m) at System.Windows.Forms.ListView.WndProc(Message& m) at System.Windows.Forms.Control.ControlNativeWindow.OnMessage(Message& m) at System.Windows.Forms.Control.ControlNativeWindow.WndProc(Message& m) at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)************** Loaded Assemblies **************mscorlib Assembly Version: 2.0.0.0 Win32 Version: 2.0.50727.42 (RTM.050727-4200) CodeBase: file:///C:/WINXP/Microsoft.NET/Framework/v2.0.50727/mscorlib.dll----------------------------------------W7T Assembly Version: 1.3.0.98 Win32 Version: 1.3.0.98 CodeBase: file:///D:/Download/W7T130-98RC/W7T.exe----------------------------------------System.Windows.Forms Assembly Version: 2.0.0.0 Win32 Version: 2.0.50727.42 (RTM.050727-4200) CodeBase: file:///C:/WINXP/assembly/GAC_MSIL/System.Windows.Forms/2.0.0.0__b77a5c561934e089/System.Windows.Forms.dll----------------------------------------System Assembly Version: 2.0.0.0 Win32 Version: 2.0.50727.42 (RTM.050727-4200) CodeBase: file:///C:/WINXP/assembly/GAC_MSIL/System/2.0.0.0__b77a5c561934e089/System.dll----------------------------------------System.Drawing Assembly Version: 2.0.0.0 Win32 Version: 2.0.50727.42 (RTM.050727-4200) CodeBase: file:///C:/WINXP/assembly/GAC_MSIL/System.Drawing/2.0.0.0__b03f5f7f11d50a3a/System.Drawing.dll----------------------------------------System.Configuration Assembly Version: 2.0.0.0 Win32 Version: 2.0.50727.42 (RTM.050727-4200) CodeBase: file:///C:/WINXP/assembly/GAC_MSIL/System.Configuration/2.0.0.0__b03f5f7f11d50a3a/System.Configuration.dll----------------------------------------System.Xml Assembly Version: 2.0.0.0 Win32 Version: 2.0.50727.42 (RTM.050727-4200) CodeBase: file:///C:/WINXP/assembly/GAC_MSIL/System.Xml/2.0.0.0__b77a5c561934e089/System.Xml.dll----------------------------------------************** JIT Debugging **************To enable just-in-time (JIT) debugging, the .config file for thisapplication or computer (machine.config) must have thejitDebugging value set in the system.windows.forms section.The application must also be compiled with debuggingenabled.For example:<configuration> <system.windows.forms jitDebugging="true" /></configuration>When JIT debugging is enabled, any unhandled exceptionwill be sent to the JIT debugger registered on the computerrather than be handled by this dialog box.and in the mount log it says:[1468] OpenFilterPort:(326): The service cannot be started, either because it is disabled or because it has no enabled devices associated with it.[1468] FltCommVerifyFilterPresent:(630): The service cannot be started, either because it is disabled or because it has no enabled devices associated with it.[1468] WIMMountImageHandle:(764): The service cannot be started, either because it is disabled or because it has no enabled devices associated with it.[1468] StateStoreRemoveMountedImage:(1041): The system cannot find the file specified.[1468] WIMMountImageHandle:(987): The system cannot find the file specified. Quote
