Posted January 29, 201213 yr DXTool x64 v1.2.1.1 Update (22 March 2017) Update (22 March 2017) Update (22 March 2017) Update (22 March 2017) Update (22 March 2017) Update (22 March 2017)Hash MD5 DD7B4EB2CBE0330F73D855C8FAEFAD98Filesize: 2.13 MB (2228224 bytes) DXTool x86 v1.2.1.1 Update (22 March 2017) Update (22 March 2017) Update (22 March 2017) Update (22 March 2017) Update (22 March 2017) Update (22 March 2017)Hash MD5 C06B72F253342DEDDE16D373BA619EC1Filesize: 2.09 MB (2192896 bytes) This handy tool for Send To menu includes CabTool, Reg2Inf & Inf2Reg converters, Tweaks True AddOn Creator, Grant Full Admin Control tool (Permissions and Ownership: 4 times faster than subinacl.exe & SetAcl.exe) and in the latest version, ISO tool (oscdimg.exe - Microsoft CD/DVD Premastering Utility - GUI) UPX GUI, Set Hash and other useful tools Double-click on DXtool.exe to install links in Send To menu and run DXTool.exe /Remove to remove them. Edited March 22, 20178 yr by nonno fabio updated
January 23, 201411 yr Author DX Tool v.1.1.5.8 releasednew: CabTool can support Unicode languages (DXTool uses CabiNet.dll now) new: UPX Tool works also on 64bit files.
February 9, 201411 yr Author new release: fixed a bug in extract update*.cab (for WinNT6.x Vista/Seven/8.*/Next. As always in Windows XP "msdelta.dll" file - WindowsXP-MSCompPackV1 - KB927374 - must be present in system)
March 9, 201411 yr Hihow to use Goscdimg exactly??when i point iso folder to it it return Error about boot sector file
March 9, 201411 yr Yes, that's what i'm using, but it gives errormy system is Windows 8.1 x86, so does the iso
March 9, 201411 yr I think the error is clear can not find etfsboot.com, the DXTool if can not find the %WinDir%\System32\Oscdimg.exe && %WinDir%\System32\etfsboot.com will automatically download from microsoft.com, copy the folder (the folder where you extracted the iso, the folder that contains the setup.exe and autorun.inf and sources\install.wim ect ect ect) to the desktop (for safety), and make sure that the Oscdimg.exe && etfsboot.com are in %WinDir%\System32 DXTool.exe /GOscdimg "%Dir%\GRTMPVOL":: will create the %Dir%\GRTMPVOL.isoDXTool.exe /GOscdimg "%Dir%\GRMCULXFRER_EN_DVD":: will create the %Dir%\GRMCULXFRER_EN_DVD.iso:: Other (Optional) options are:: /C="put\use a custom commandline" ;; example "-h -n -m" :: /P="FullPath Oscdimg.exe" ;;example "C:\Program Files\Windows Kits\8.1\Assessment and Deployment Kit\Deployment Tools\x86\Oscdimg\oscdimg.exe":: /B="FullPath etfsboot.com" ;;example "C:\Program Files\Windows Kits\8.1\Assessment and Deployment Kit\Deployment Tools\x86\Oscdimg\etfsboot.com":: /A="1 or 2" ;;1 = Replace, if destination file exists, 2 = Rename, if destination file exists:: /O="save the ISO in another destination" ;;example "C:\Name":: exampleDXTool.exe /GOscdimg /O="C:\XPCD" "%Dir%\GRTMPVOL":: will create the C:\XPCD\GRTMPVOL.isoDXTool.exe /GOscdimg /A="2" "%Dir%\GRTMPVOL":: (by default) if the %Dir%\GRTMPVOL.iso already exists, will create the %Dir%\GRTMPVOL (2).isoDXTool.exe /GOscdimg /A="1" "%Dir%\GRTMPVOL":: if the %Dir%\GRTMPVOL.iso already exists, replaces itCiao.System32.zip Edited March 9, 201411 yr by OnePiece
March 10, 201411 yr I thought it's designed to pickup \boot\etfsboot.com in the iso folder, not from System32 thanks for the clear up!
June 16, 201410 yr Thanks for the Grant Admin Full Control Tool.I tested on "C:\Program Files\JDownloader v2.0", which have 231 MB and 6.521 Files, 220 Folders.Using an context menu entry made by me, which use setacl.exe 64-bit recursively and that change the owner and set permissions to the current user logged in, the total time used was 44 sec.Using Grant Admin Full Control Tool, which works recursively also and change the owner and set permissions to the current user logged in, the total time used was less than 4 seconds, with the same results.
March 31, 201510 yr DXTool 1.2.0.6 x64 generates bad checksums for files larger than 4GB. Are different from those generated by Hashcheck and eXpress CheckSum Calculator - that are compatible. For files larger than 4GB all the sum of each program are consistent. Repeatedly tested on Windows 7 Pro x64 SP1. Tested on ISO images systems. Edited March 31, 201510 yr by wiktorynka
April 1, 201510 yr Hi wiktorynka, Thanks for the info, is my fault for better performance i used the FileMapping ehhh, however already fixed, indeed also added ProgressBar Ciao.
April 1, 201510 yr Thank you for a great tool. Now in version 1.2.0.7 is all right.P.S. Why your servers are 3 different versions of DXTool 1.2.0.7? Is differ only in the degree of compression? Edited April 6, 201510 yr by wiktorynka
August 8, 20168 yr updated, Fixed a problem in cabview.dll in Windows 10 Anniversary Update Ciao a tutti.
June 9, 20177 yr Almost nobody uses it now, but ehhh, Here is Reg2Inf written in C++, Obviously it is very much much faster than the one written in Autoit, Let's say converts a file.reg (1GB) in about 3.5 seconds ehhhhh, From the tests made with a file.reg 300 MB (the HKLM in Windows 10 x64) I would say almost 90 times faster than that written in Autoit, However those who like to play here are the link Reg2Inf Tool x32 Update (9 June 2017) Update (9 June 2017) Update (9 June 2017) Update (9 June 2017) Update (9 June 2017) Update (9 June 2017) Update (9 June 2017) Update (9 June 2017)Hash MD5 CD449F7CA5589870E948584F041D8F20Filesize: 142 KB (145408 bytes) Reg2Inf Tool x64 Update (9 June 2017) Update (9 June 2017) Update (9 June 2017) Update (9 June 2017) Update (9 June 2017) Update (9 June 2017) Update (9 June 2017) Update (9 June 2017)Hash MD5 7D0CFD90C98F8108D3F00BAFFAC02CF9Filesize: 160 KB (164352 bytes) As always just run it from the command lineReg2Inf.exe /RTI file.reg Or as always just create a link, copy it to %UserProfile%\AppData\Roaming\Microsoft\Windows\SendTo ect ect Ciao a tutti.
June 15, 20177 yr Thanks OnePiece... I use reg2inf constantly.... So I really appreciate the rewrite...
July 13, 20177 yr Hi *Reaper* Thank You @All DXTool BETA x64 Update (2 September 2017) Update (2 September 2017) Update (2 September 2017) Update (2 September 2017) Update (2 September 2017) Update (2 September 2017)Hash MD5 5933E3965452379338D726CDA0678A5BFilesize: 275 KB (281600 bytes) DXTool BETA x86 Update (2 September 2017) Update (2 September 2017) Update (2 September 2017) Update (2 September 2017) Update (2 September 2017) Update (2 September 2017)Hash MD5 C4ACDE86764DC2D2ED765AB0330AE5E4Filesize: 246 KB (252416 bytes) added CabTool and HashTool which means support the DXTool.exe /RTI file.reg DXTool.exe /CT FilePath DXTool.exe /MD5 FilePath DXTool.exe /SHA1 FilePath DXTool.exe /SAOD FilePath DXTool.exe /GOscdimg FolderPath DXTool.exe /GUPX FilePath DXTool.exe /7ZSplit FilePath DXTool.exe /DRE FilePath.dll Ciao a tutti.
