Adding your registry tweaks to your windows xp/2003/vista/seven image is very easy with DX Tool
Right click on your tweak .reg file (you can find a lot of tweaks googling for "Collection + Registry Tweaks", for example http://www.askvg.com...-for-windows-7/) and in Send To menu send it to DX Registry TWEAKS True AddOn Creator. Done!
It is suggested to rename tweak .reg file to made it 8.3 compatible as the resulting .inf file will take the same name.
So Enable addition Avalon effects.reg file should be EAAE.reg
