Hello!
When i want to install nero 7, the installation freezes. It freezes right after i check the License Agreement and i press Next. I was searching a bit on google, and found that maybe you need to disable antivirus. Well, i did it and nothing new happend. Only if i didnt full disable it. Antivirus is actually that pack from Norton (Norton Internet Security) which i got with my new laptop (usually i dont use norton). Any suggestions?
Hf
If you can't get to go, try installing Nero 7 lite. The download file is 12mb and you can use your existing Nero 7 cd key to install it. It just has the Nero burning rom with nothing else. Really good IMO. Less stuff to install.
Yup, depending on your system specs, you might have to wait for the package to extract all the files.
I agree, nero lite is the best. I also don't use all the crap that installs with Nero except the main nero burning program.
