An easy to use 7-Zip toolbar and filetype theme manager.
Many users of the excellent file archiver 7-Zip criticized its nostalgic appearance.
That's exactly where 7-Zip Theme Manager (7zTM) comes in and offers the tools to change the appearance of the archiver.
7-Zip Theme Manager will also help you replace the standard icon which 7-Zip uses for
SFX-archives (self-extracting archives) via a button in the main menu, so that it will be used for all future archives.
Here are some key features of "7-Zip Theme Manager":
Stylish:
· Toolbar Themes - change the look of the toolbar of 7-Zip
· Filetype Themes - change the look of archived files, for instance in Explorer
· 90 Toolbar Themes and 22 Filetype Themes integrated (wow!)
· changing the SFX-icon (self-extracting archive) is now possible
Handy:
· automatic or manual search of the 7-Zip installation folder
· convenient activation of the Themes with just a click
· Themes previews integrated directly into the program
· multi-lingual user interface
· online update for up to date Themes and features
· possibility to create your own Themes
· supports 7-Zip 32-Bit and 64-Bit
Requirements:
· 7-Zip 4.65 or above (I tested with my own v9.22 beta True addon)
· Administrative rights
Access from All User's Start Menu: 7-zip Theme Manager
Uninstallable from Add/Remove Panel
Languages: German, English, Italian
7ZipThemeManager21_addon.cab
Size: 9.12 Mb (9,560,168 bytes)
MD5: 3022F8CB5D41ED993F44CE68F60494F6
Note: This addon is not suitable with 7-Zip 9.23 alpha.
You need 7zTM.exe with version 2.1.1 for 7-Zip 9.23 alpha. (Not included in this addon)
  • 5 months later...
