adminxp Posted February 10, 2012 Posted February 10, 2012 bug - tweak remove default prg doesn't work Quote
Legolash2o Posted February 18, 2012 Posted February 18, 2012 It doesn't remove that, check the attached picture... Quote
bphlpt Posted February 18, 2012 Posted February 18, 2012 So the OP is correct? The tweak doesn't work? Or do we just misunderstand what it is supposed to do?Cheers and Regards Quote
Legolash2o Posted February 18, 2012 Posted February 18, 2012 (edited) The tweak removes what i put a red square on in my pic above.EDIT: I've added code which will also remove the link in the first post, just need to test it although i'm not sure it will work on non-English version. Edited February 18, 2012 by Legolash2o Quote
