nice_guy75 Posted February 20, 2012 Posted February 20, 2012 I was trying to integrate some themes and making one of them as default theme, also trying to integrate some gadgets, I got this error:I have also changed the permissions of all the files of "windows\system32\config" folder as well before attempting to integrate themes and gadgets.I have attached last sessions.ini, mount log and settings as well.Please help me mate, I have tried almost 3-4 times and I got this error all the times.Last Sessions.rar Quote
chmakoto Posted March 6, 2012 Posted March 6, 2012 This will not be much help other than to say I am having a similar problem. I used the Home Premium Disk, I copied all the files from it to a Win7Lite directory so I could use undamaged files for my build. Using the All-In-One tool, I selected some components to be removed, e.g. some language packs. I am getting the following error message over and over as Win Tools is building an image. As you see it is very similar to the one listed above. Any suggestions will be appreciated. By the way, I have Kaspersky Pure installed. Could it be interferring with Win7Tool Kit's access to the registry? Quote
bphlpt Posted March 6, 2012 Posted March 6, 2012 It is ALWAYS STRONGLY suggested to temporarily disable ALL antivirus and antimalware apps of any kind when you are running any builder type app such as W7T. Unplug from the internet while you are "vulnerable" if you are concerned. Use apps from trusted sources and run full system scans on a regular basis and you shouldn't have anything to worry about.Cheers and Regards Quote
Legolash2o Posted March 6, 2012 Posted March 6, 2012 (edited) Have you guys tried it after turning off your anti-virus?EDIT: Which anti-virus do you guys have installed? Edited March 6, 2012 by Legolash2o Quote
nice_guy75 Posted March 10, 2012 Author Posted March 10, 2012 Have you guys tried it after turning off your anti-virus?EDIT: Which anti-virus do you guys have installed?I am using Eset NOD32 v5.0.95.0, but I don't think is has something to do with AV, as I have been using your tool without disabling the AV. This is the first time I have encountered such error.Anyways, when I tried after few days it worked perfectly. I don't remember at that time I disabled the AV or not, as I do disable my AV every now and then for different reasons. Quote
