March 6, 201213 yr Would be real handy feature.Unfortunately, I never encountered that graphics glitch...
March 6, 201213 yr Strange that seems to be v2.1.4.1 installer whilst the latest is v3.2.0.0, i think that fixed that graphics glitch a long time ago.EDIT: Seems like i had an error in my code, if the program already existed then it won't update it. However if you use silent installers from the next release (v101) it will update it Edited March 6, 201213 yr by Legolash2o
March 8, 201213 yr Author Strange that seems to be v2.1.4.1 installer whilst the latest is v3.2.0.0, i think that fixed that graphics glitch a long time ago.EDIT: Seems like i had an error in my code, if the program already existed then it won't update it. However if you use silent installers from the next release (v101) it will update it Can I make an installer program separately from the Windows 7 Toolkit and in the process of creating the image of the installer copied to the image as it is done in RTWin7Lite? This is necessary in order to locate the installer on the user's language in this case Russian. I have to extract the installer from the image, translate it and then re-packaged in a way, and this increases the size of a Windows.
March 8, 201213 yr Author Strange that seems to be v2.1.4.1 installer whilst the latest is v3.2.0.0, i think that fixed that graphics glitch a long time ago.Windows7-Toolkit version 102 still generates an installer version 2.1.4.1 W7TRunOnce
March 8, 201213 yr When you ran W7T again in v101+ did you add anything to the silent installer list?P.S. In v103 you can double-click on the syntax column and edit it. Edited March 8, 201213 yr by Legolash2o
March 8, 201213 yr You've already requested this in another topic, either way it's done so closing thread...EDIT: I've merged the two threads together. Edited March 8, 201213 yr by Legolash2o
