Posted March 7, 200718 yr You have much better luck asking Rafael and ZoRoNaX creators of VAIO @ http://www.aeroxp.org/board/index.phpI heard from Rafael that they are working on Vistas Calendar...Off Topic: xhch18 do you have Texas Holdem Vista Ultimate Extra?If you do can you upload it to http://mihd.net/ So do you have Texas Holdem for Vista?? If you do can you please upload it somewhere, it takes forever to download it from "Automatic Updates" !Thnx. Edited March 3, 201213 yr by dougiefresh HiJacking topic split from original topic
March 7, 200718 yr Here is a direct link for Holdem http://www.download.windowsupdate.com/msdo...b14a00b3775.cab
March 8, 200718 yr Author Here is a direct link for Holdem http://www.download.windowsupdate.com/msdo...b14a00b3775.cabThnx m8. I'm just downloading it. How to install cab file in Vista ??CYGNUS: Thnx for offering I'v download it from ricktendo64 link :welcome: .Regards.
March 9, 200718 yr Author You will need a special Vista Hotfix extractor for HoldemI tried to Google for extractor but no luck. Any directions... ?Thnx.
March 15, 200717 yr Author Hey guys any luck finding Hotfix extractor??? I'm still unable to find a way to install cab file in vista :sad01_anim: . Any help appreciated.
March 15, 200717 yr I have a SendTo AddOn of a Vista Hotfix Extractor for XP thatYou can find the HF Extractor here on Xables forum http://hotfix.xable.net/board/index.php?showtopic=140
March 15, 200717 yr Here it is Racker, I saved you time for registering on that forum..Here`s a compiled autoit script to extract hotfixes.Just drap the update onto the .exe and it`ll extract the files to a folder in the same dir as the hotfix.HFExtract_ENG.exe
March 16, 200717 yr Author Here it is Racker, I saved you time for registering on that forum..Here`s a compiled autoit script to extract hotfixes.Just drap the update onto the .exe and it`ll extract the files to a folder in the same dir as the hotfix.Thnx N1K :worthy: . Now what??? I'v extracted all files and ....where do I put them, how do I install them? :sigh:
July 26, 200717 yr Hey guys any luck finding Hotfix extractor??? I'm still unable to find a way to install cab file in vista :sad01_anim: . Any help appreciated.Try the tool i posted here : http://www.wincert.net/forum/index.php?showtopic=985It can do cab files as well.
November 9, 200816 yr Racker did you make it work, im also stuck at extracting and now what (btw im tryinh dreamscene)...
