Legolash2o Posted March 5, 2012 Posted March 5, 2012 (edited) Since v1.3.0 doesn't seem perfect yet i've decided to re-open this thread.This thread is for....Spelling Mistakes / Typo'sMinor Glitches i.e. progress bar is full when it shouldn't beTiny suggestions of how something can be tweaked slightly to work or look better.Anything minorThis thread is NOT for...Bugs - they need their own topicRequests - they should go in the request forum.Nothing that requires a lot of work, refer to 1 and 2.I look forward to hearing your feedback.NOTE: If you have already made a topic about a bug and it's not fixed yet, then give it a 'bump'. Edited March 5, 2012 by Legolash2o Quote
Eric666 Posted March 5, 2012 Posted March 5, 2012 (edited) Well, to start with minors:Main form:Tooltip for AIO: ...this tool let's you... (should be: lets you)Tooltip for AIO: line about drivers contains typo (says dirvers)Tooltip for AIO: line about theme packs has typo for favouritesTooltip for AIO: line about language packs: is -> inTooltip for AIO: line about wallpapers: you -> yourTooltip for WIM Manager: export imagex (should be images?)Tooltip for CAB retriever: lot's -> lots; let's -> letsTooltip for W7T Guide: your -> you'reOptions -> Main tabTooltip for Check images: corrupted is misspelledWIM Manager:Tooltip for Browse for WIM: Windows is misspelledRegards, EricBPS is it possible to make a dump of all tooltip text for review? Makes life much easier :grin: Edited March 5, 2012 by Legolash2o Quote
Legolash2o Posted March 5, 2012 Author Posted March 5, 2012 Done, thanks. I've also fixed a view other "let's".It is possible but it would take some time, which i don't have Quote
