Wyatt Posted March 8, 2012 Posted March 8, 2012 One issue I am having with the 1.3.0.98 Release - is in the WIM manager. If I select the WIM to edit, such as name or description...and type in the text as usual - it refuses to show the change(s) within the GUI - as if it just ignored the edit.I just went back to the 1.3.0.5 version being able to use this feature where it still works fine....until this particular issue can be addressed.Thanks for your time! Quote
Legolash2o Posted March 8, 2012 Posted March 8, 2012 (edited) v1.3.0.102 is out now, but i'll test it anyway EDIT: Works fine for me although i have fixed a bug which says '' name already exists... Edited March 8, 2012 by Legolash2o Quote
Legolash2o Posted March 9, 2012 Posted March 9, 2012 I still can't reproduce this issue? anyone else having difficulty?P.S.*1.3.0.83B^W7T now uses wimgapi to rename images and keeps displayname and displaydescriptionSo v82 should be fine to use instead of v5 Quote
Wyatt Posted March 21, 2012 Author Posted March 21, 2012 Thanks for the response and assistanceLegolash2o - however I did try the latest version (1.3.0.102) - and I still get the same issue. When I use the WIM manager, selecting a WIM that is already named after using WAIK/imagex - the name shows, and description says usual "No Description", but when I select to edit the description...the new edit will not show...always still says "No Description". When I use the older version (1.3.0.5), it does fine...edits and shows the description name, as well as the WIM name itself. Any further insight(s) would be appreciated. Quote
Legolash2o Posted March 21, 2012 Posted March 21, 2012 (edited) Ahh, i know the issue now. I'll take a look. Thanks.EDIT: It is just the description which won't change? Name changes fine? EDIT 2: Can you open your install.wim with 7zip and send me the 1.xml file within it please. Edited March 21, 2012 by Legolash2o Quote
Wyatt Posted April 10, 2012 Author Posted April 10, 2012 Thanks for the help. I attached the xml of the version I have and the windows PE xml - since it is a sysprep/imagex build. Sorry it took me a while - but other work had me stuck. Great work on the WinKit new version! - yet same error on it as well...I can edit WIM name, but when I try the description - I always get a error box titled "Error setting WIM info" and message "The parameter is incorrect"...why this error keeps following me I have no idea.Still using the older win7 toolkit 1.3.0.5 to fully rename/edit both name and description of WIM's since it still works for some reason.Hope this helps - but if not - let me know if anything else.Thanks againWyatt1.xmlUltimate.xml Quote
