alfreire Posted March 9, 2012 Posted March 9, 2012 Hello... when I import this reg file in WIM Registry Editor:Windows Registry Editor Version 5.00;Disable User Account Control ( UAC )[HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Policies\System]"ConsentPromptBehaviorAdmin"=dword:00000000"ConsentPromptBehaviorUser"=dword:00000000"EnableInstallerDetection"=dword:00000000"EnableLUA"=dword:00000000"EnableUIADesktopToggle"=dword:00000000"EnableSecureUIAPaths"=dword:00000000"PromptOnSecureDesktop"=dword:00000000"ValidateAdminCodeSignatures"=dword:00000000"FilterAdministratorToken"=dword:00000000[HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Security Center]"UacDisableNotify"=dword:00000001[HKEY_CLASSES_ROOT\CLSID\{20D04FE0-3AEA-1069-A2D8-08002B30309D}\shell]@="none"[HKEY_CLASSES_ROOT\CLSID\{20D04FE0-3AEA-1069-A2D8-08002B30309D}\shell\DevMgr]@="Administrador de Dispositivos"[HKEY_CLASSES_ROOT\CLSID\{20D04FE0-3AEA-1069-A2D8-08002B30309D}\shell\DevMgr\command]@="mmc /s devmgmt.msc"[HKEY_CLASSES_ROOT\CLSID\{20D04FE0-3AEA-1069-A2D8-08002B30309D}\shell\DiskMgmt]@="Administrador de Discos"[HKEY_CLASSES_ROOT\CLSID\{20D04FE0-3AEA-1069-A2D8-08002B30309D}\shell\DiskMgmt\command]@="mmc /s diskmgmt.msc"[HKEY_CLASSES_ROOT\CLSID\{20D04FE0-3AEA-1069-A2D8-08002B30309D}\shell\Add/Remove Programs]@="Desinstalar Programas"[HKEY_CLASSES_ROOT\CLSID\{20D04FE0-3AEA-1069-A2D8-08002B30309D}\shell\Add/Remove Programs\command]@="control appwiz.cpl"[HKEY_CLASSES_ROOT\CLSID\{20D04FE0-3AEA-1069-A2D8-08002B30309D}\shell]@="none"[HKEY_CLASSES_ROOT\CLSID\{20D04FE0-3AEA-1069-A2D8-08002B30309D}\shell\Windows Update]"Icon"=hex(2):77,00,75,00,63,00,6c,00,74,00,75,00,78,00,2e,00,64,00,6c,00,6c,\ 00,00,00[HKEY_CLASSES_ROOT\CLSID\{20D04FE0-3AEA-1069-A2D8-08002B30309D}\shell\Windows Update\command]@="wuapp.exe"[HKEY_CURRENT_USER\Software\Microsoft\CTF\LangBar]"ShowStatus"=dword:00000003[HKEY_CLASSES_ROOT\Directory\shell\runas]@="Abrir CMD aquí"[HKEY_CLASSES_ROOT\Directory\shell\runas\command]@="cmd.exe /s /k pushd \"%V\""the key for disable Language Bar not import to registry...[HKEY_CURRENT_USER\Software\Microsoft\CTF\LangBar]"ShowStatus"=dword:00000003When Windows is totally instaled and I edit registry, Langbar key not exist...Sorry for my bad english...Regards... ;-) Quote
Legolash2o Posted March 9, 2012 Posted March 9, 2012 Yeah, this issue has been around for some time, i don't know what causes it. It seems to get reset after Windows installation. Quote
Kelsenellenelvian Posted March 9, 2012 Posted March 9, 2012 HKEY_CURRENT_USER <--- HKCU is most likely the issue as that key doesnt get full populated untill after first logon... Quote
Legolash2o Posted March 9, 2012 Posted March 9, 2012 The HKEY_CURRENT_USER get gets converted to HKEY_USERS\.Default Quote
alfreire Posted March 9, 2012 Author Posted March 9, 2012 Yeah, this issue has been around for some time, i don't know what causes it. It seems to get reset after Windows installation.HKEY_CURRENT_USER <--- HKCU is most likely the issue as that key doesnt get full populated untill after first logon...Thank you... I'll try to add reg key through WPI...Regards... ;-) Quote
alfreire Posted March 9, 2012 Author Posted March 9, 2012 The HKEY_CURRENT_USER get gets converted to HKEY_USERS\.DefaultAny solution...? Quote
Legolash2o Posted March 9, 2012 Posted March 9, 2012 (edited) in v103 i've updated my code to unregister a dll in the runonce key. Haven't tested if it works yet though..."HKEY_LOCAL_MACHINE\\Software\\Microsoft\\Windows\\CurrentVersion\\RunOnce", "Remove LangBar", "Regsvr32.exe /s /u msutb.dll", RegistryValueKind.String Edited March 9, 2012 by Legolash2o Quote
alfreire Posted March 9, 2012 Author Posted March 9, 2012 in v103 i've updated my code to unregister a dll in the runonce key. Haven't tested if it works yet though..."HKEY_LOCAL_MACHINE\\Software\\Microsoft\\Windows\\CurrentVersion\\RunOnce", "Remove LangBar", "Regsvr32.exe /s /u msutb.dll", RegistryValueKind.StringI will try it and notify to you... :beerchug:Thank's and regards... ;-) Quote
alfreire Posted March 13, 2012 Author Posted March 13, 2012 Hello again... I have another problem, I created a DisableLangBar.cmd with the following code REG ADD "HKCU\Software\Microsoft\CTF\LangBar" /v ShowStatus /t REG_DWORD /d 3 /fdoes not get it to work, if I run from the console command works, but if I run the DisableLangBar.cmd not... Any ideas...?Regards... ;-) Quote
bphlpt Posted March 13, 2012 Posted March 13, 2012 When do you try to run the DisableLangBar.cmd that it does not work? At install, on a live system, anytime, or ...?Cheers and Regards Quote
alfreire Posted March 13, 2012 Author Posted March 13, 2012 (edited) When do you try to run the DisableLangBar.cmd that it does not work? At install, on a live system, anytime, or ...?Cheers and RegardsI run DisableLangBar.cmd in a complete install system Windows 7 Pro x64 SP1...Tnahk you... ;-) Edited March 13, 2012 by alfreire Quote
alfreire Posted March 13, 2012 Author Posted March 13, 2012 (edited) Can I run code from Autounattend.xml...?<SynchronousCommand wcm:action="add"> <CommandLine>cmd /q /c REG ADD "HKCU\Software\Microsoft\CTF\LangBar" /v ShowStatus /t REG_DWORD /d 3 /f</CommandLine> <Description>Disable LangBar</Description> <Order>2</Order> <RequiresUserInput>true</RequiresUserInput></SynchronousCommand> Edited March 13, 2012 by alfreire Quote
bphlpt Posted March 13, 2012 Posted March 13, 2012 (edited) I run DisableLangBar.cmd in a complete install system Windows 7 Pro x64 SP1...Tnahk you... ;-)The reason I asked is that this will NOT work during the OS install if it is run too early, since "Current User" - (HKCU) - will not exist at that point as Kel pointed out. So it will not work in Autounattend.xml for the same reason. But I might have misunderstood you. It should work if you run the DisableLangBar.cmd AFTER first log on, using WPI for example. Of course you'll have to run this for each user you want it to apply to.Cheers and Regards Edited March 13, 2012 by bphlpt Quote
Legolash2o Posted March 13, 2012 Posted March 13, 2012 Make it run at HKCU\\Software\Windows\CurrentVersion\RunOnce, worth a try. Quote
alfreire Posted March 13, 2012 Author Posted March 13, 2012 The reason I asked is that this will NOT work during the OS install if it is run too early, since "Current User" - (HKCU) - will not exist at that point as Kel pointed out. So it will not work in Autounattend.xml for the same reason. But I might have misunderstood you. It should work if you run the DisableLangBar.cmd AFTER first log on, using WPI for example. Of course you'll have to run this for each user you want it to apply to.Cheers and RegardsOk, thank you... :beerchug:Make it run at HKCU\\Software\Windows\CurrentVersion\RunOnce, worth a try.Ok, I promise you try it... how I run"HKEY_LOCAL_MACHINE\\Software\\Microsoft\\Windows\\CurrentVersion\\RunOnce", "Remove LangBar", "Regsvr32.exe /s /u msutb.dll", RegistryValueKind.String...?From Auntounattend.xml, *.cmd, $OEM$ folder...???Thank you again... ;-) Quote
alfreire Posted March 13, 2012 Author Posted March 13, 2012 Is this ok...?Windows Registry Editor Version 5.00[HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\RunOnce]"DisableLangBar"="Regsvr32.exe /s /u msutb.dll" Quote
bphlpt Posted March 13, 2012 Posted March 13, 2012 Hello again... I have another problem, I created a DisableLangBar.cmd with the following codeREG ADD "HKCU\Software\Microsoft\CTF\LangBar" /v ShowStatus /t REG_DWORD /d 3 /fdoes not get it to work, if I run from the console command works, but if I run the DisableLangBar.cmd not... Any ideas...?Regards... ;-)Since you say this DisableLangBar.cmd runs correctly as you show it when run from the command line, then leave it exactly like it is and run it with WPI. HKCU exists when WPI runs so it should work just fine. But you can try any other method you like. If you find one that works for you, then please post it so others will know a method you have verified that works.Cheers and Regards Quote
alfreire Posted March 13, 2012 Author Posted March 13, 2012 (edited) in v103 i've updated my code to unregister a dll in the runonce key. Haven't tested if it works yet though...*"HKEY_LOCAL_MACHINE\\Software\\Microsoft\\Windows\\CurrentVersion\\RunOnce", "Remove LangBar", "Regsvr32.exe /s /u msutb.dll", RegistryValueKind.StringSince you say this DisableLangBar.cmd runs correctly as you show it when run from the command line, then leave it exactly like it is and run it with WPI. HKCU exists when WPI runs so it should work just fine. But you can try any other method you like. If you find one that works for you, then please post it so others will know a method you have verified that works.Cheers and RegardsWell, well... I want try *Legolash2o method to help, but I don't know how... I guess the other methods that work...Thank you very much, friend... ;-) Edited March 13, 2012 by alfreire Quote
alfreire Posted March 15, 2012 Author Posted March 15, 2012 [HKEY_CURRENT_USER\Software\Microsoft\CTF\LangBar]"ShowStatus"=dword:00000003Well... I try DisableLangBar.reg through WPI, and work perfect... The Legolash2o method I don't know how to test it...Thanks and sorry if I bothered...Regards... ;-) Quote
alfreire Posted March 29, 2012 Author Posted March 29, 2012 Hi ... I found the Registry error... The problem is that User Account settings do not apply to the User Administrator Account ... I loaded the User Administrator Account hive with the WIM Registry Editor, I have set it LangBar adjust manually and it works ... Could you make User settings also apply to the Administrator account?Thank's and regards... :cap: Quote
alfreire Posted March 29, 2012 Author Posted March 29, 2012 (edited) One question, when I import a *.reg file in WIM Regystry Editor, It's import to hive selected, or indifferent? how I import settings with *.reg file to User Admin Account?If [HKEY_CURRENT_USER] is for Current User (in *.reg file), how to set for Admin User...?Thank's and sorry for my bad english... ;-) Edited March 29, 2012 by alfreire Quote
Legolash2o Posted March 29, 2012 Posted March 29, 2012 Hi ... I found the Registry error... The problem is that User Account settings do not apply to the User Administrator Account ... I loaded the User Administrator Account hive with the WIM Registry Editor, I have set it LangBar adjust manually and it works ... Could you make User settings also apply to the Administrator account?Thank's and regards... :cap:Ok i've just programmed W7T to apply tweaks to BOTH "WIM_Admin" and "WIM_Default"One question, when I import a *.reg file in WIM Regystry Editor, It's import to hive selected, or indifferent? how I import settings with *.reg file to User Admin Account?If [HKEY_CURRENT_USER] is for Current User (in *.reg file), how to set for Admin User...?Thank's and sorry for my bad english... ;-)As above, v1.4.0.3 will write to both places. Quote
bphlpt Posted March 29, 2012 Posted March 29, 2012 So this be used to make changes to the CurrentUser in offline systems before it is built? Even though that account doesn't exist before first logon? Or does this only work on active installed systems?Cheers and Regards Quote
