I'm requesting feedback on the new Tools Manager and some other tools. When i first started W7T it was mainly for experienced users however I've noticed a lot more beginners so in v103 i have hopefully made it more easier for those types of users. I'm also going to update some error boxes to the new one i programmed, which has a more details button and there is a screenshot at the bottom.
You will notice some things look a lot more different. I've also done some minor UI changes to some other tools which are not mentioned here which are:
  • All tools windows can be resized
  • Majority of tools open in 750x400 creating more consistency
  • Some tools had panels like in Addon Maker where you add a file and a little screen pops up, these will all be centered when opened.
  • Updated some tooltips.
I'm just trying to make things more consistent and neat looking. However they're things i still need to finish of:
  • Replace old error messages boxes with my new one.
  • More tool tips to help beginners
  • Memory optimizations
I'm not adding any potentially buggy code because we are near the final, i'm just doing the things i should have finished. Once the final is released (prob v110) then i will update all the guides and include the missing ones.
Note: If you are wondering why the window titles are centered it is because i'm using Windows 8 Beta.
Change Log:
*1.4.0.1^NEW: Addon Maker lets you edit addons
*1.4.0.1^NEW: UEFI support added for ISO Maker
*1.4.0.1^NEW: Lots of GUI changes
*1.4.0.1^NEW: Driver Installer lets you install/remove drivers on the live system.
*1.4.0.1^NEW: Update Installer now lets you uninstall updates
*1.4.0.1^NEW: You can now save or load AIO lists individually without affecting the other lists
*1.4.0.1^FIX: MSU could not convert if you selected output path as drive root
*1.4.0.1^FIX: Some tools did not report which image was being mounted/unmounted properly
*1.4.0.1^FIX: Could not extract file is'SevenZipSharp.dll' was missing.
*1.4.0.1^FIX: Fixed a potential language pack integration bug.
*1.4.0.1^FIX: Fix a language pack integration bug where a 'license' folder could not be copied
*1.4.0.1^FIX: Fixed an issue where adding updates did not cancel on request using Update Integrated
*1.4.0.1^FIX: Fixed 'Read Task.txt' in AIO Integrator
*1.4.0.1^FIX: Removed hand cursor from Welcome Tab (Tools Manager)
*1.4.0.1^FIX: Current OS option in AIO did not uncheck if user selected no
*1.4.0.1^FIX: Better detection of architecture for drivers
*1.4.0.1^FIX: Some files did not extract properly if 'ExtractTo' folder was not created first
*1.4.0.1^FIX: CAB Retriever did not copy files.
*1.4.0.1^TWEAK: Change DPI Setting
*1.4.0.1^Tidied up Addon Maker, centered things, etc..
*1.4.0.1^In Addon Maker, variables will show tooltip showing where files will go
Popular
As you can see i have got the tools which i think will be useful for beginners at the very top, this will hopefully make the page look less busy and confusing.
  • Beginners
I decided to group the most important tools and probably most used at the very top so beginners can hopefully see which tools they need. Most users just want to integrate things so i've made it the first button so it's easy to find.
  • Recommended
I prefer users to have the latest Windows 7 SP1 disk and it's also recommended for users to have all the SoLoR updates integrated.
  • Other Popular Tools
These tools are for the more advanced/experienced users.
Tools
As you can see i've grouped the converters together, the tools which work using the currently installed OS together, the tools which work with wim images and then just misc stuff.
Downloads
Hopefully it looks easier to find the stuff you want.
About
I got rid of the about button/form and just added a tab with this information, nothing special.
Addon Maker
I've added a lot more features in v103, you can now load previous .WA files, edit and then save it. There is also some tooltips on the list of variables showing which folder they will be i.e. C:\Windows\System32.
I've also added a 'New' button so you can clear all the lists and start a new addon without closing the tool and re-opening it.
Capture Image
As you can see i've added some pictures, but i've also added some labels like the TIP ones. Looks quite nice on Windows 8.
ISO Maker
Again more images and a view more labels like 'Folder to capture' and 'Select where to save ISO'. ISO Maker now also supports UEFI, it allows you to choose if you want to use BIOS, UEFI, Both and Custom.
SWM Merger
Just more images and an extra label.
WIM Splitter
Same as SWM
Update Installer
The Update Installer now has an 'Installed' tab which lets you uninstall updates, useful for those who use SoLoR Updates and like to remove superseded
Driver Installer
As requested, this tool lets you install drivers onto the live system, you can also remove them too.
Error Messages
Previous if there was an error message i had to limit the amount of information displayed so the user hopefully doesn't get confused. I will slowly be replacing the old error messages with my new one so those technical people have just click 'More Detail' and it will hopefully be able to help them and me if they post it on the forum.
The new error messages has a short description and a longer but simple description underneath it. Again, this will help the less experienced users.
Edited by Legolash2o
  • Replies 112
  • Views 24.6k
  • Legolash2o
    Legolash2o
    Yeah i've renamed it the topic to show v1.4.0 If you want to be an Alpha test then please send me a Personal Message. The things i hope to get from feedback are: GUI recommendations How to make thin
  • Legolash2o
    Legolash2o
    OK, i've updated All-In-One with the new design. I've also added the new Component Removal which doesn't work yet which is why there is two in the picture. What do you guys think?
  • Count me in... :welcome:
On the Error Messages window you could move the "More/Less Info" button to the bottom and add the "expand" and "colapse" sign to it according, looking more professional. Hope you get what I mean.
Done.
Re-check my first post, i've redone the error box taking in your suggestions :)
Driver installer looks gr8
Glad you liked it :D
Just got a chance to review and you did sooo much.. here's my take:
1) The overall look is extremely clean and sharp... very nice
2) The groups are an excellent addition and are very helpful to both beginners and advance alike
3) I think you should still keep a link to the forum somewhere
4) Some additional explanatory pop-ups over the icons would be helpful
5) Driver and Update installers are clean and straight forward
Overall very nice IMHO... THANK YOU!!!
Edited by compstuff
1) Thanks
2) Thanks
3) It's on the sidebar, the button with the picture of a home, "Visit the W7T Forum'
4) I'm assuming for the buttons on the main form?
5) That's what i was aiming for :D
Glad you like it :)
Can't believe I missed the damn forum link because I didn't enlarge the image DUH :-)
Forget my #4 because once an updated guide is available and a link to it is provided then the existing pop-ups are fine
Not sure what others think regarding the version but this is a pretty significant visual and layout change so I think 1.4 is appropriate
1) Thanks
2) Thanks
Glad you like it :)
Yeah i've renamed it the topic to show v1.4.0 :D
  • GUI recommendations
  • How to make things easier for beginners
  • Just suggestions in general
  • Changes to Tooltips
  • Any error messages which use the old style.
Bugs should go in a new topic and requests should go in the request forum. However if you want me to make a slight edit to anything in the 1st post then you can post it here, but anything big then then i will move it to the request forum for you :)
P.S. Just in case you missed my edit on the first post, i've added UEFI support in ISO Maker.
Just a thought, under ISO Maker, a function that I can include a folder from a different location than where the folder being captured...
The overall appearance looks very professional.... :)
oh I forgot, great job on the new error message... B) It's a great help, it will take out guess work...
Edited by Cipherfx2
I have downloaded and look at v1.3.0.102
Thanks for your hard work.
I like it very much. No any new idea for now.
Let's hurry for final version because win8 is coming :)
Alpha Tester places remaining: 4
Ok guys, a lot of has changes since the 1st post, here's an update. I've basically just added more tooltips and changed some too, i've also renamed some stuff.
I've fixed a lot of bugs in v1.4.0
*1.4.0.1^In Addon Maker variables will show tooltip showing where files will go
You will notice that there is two language pack bugs, you should no longer have any issues regarding the language packs anymore :D
I'm on it, thanks again ~
Your welcome.
As you know there are soo many tweaks in the All-In-One Tools it's pretty scary. Does anyone have any ideas on how to improve this and make it look less complicated.
Even offer tweaks which i can remove! This is not the place to request tweaks, the correct place is here.
Thanks.
