Posted March 13, 201213 yr After creating the file Autounattend.xml with Windows 7 Toolkit, Windows does not understand it. If you create a Autounattend.xml in the Rtlite or Windows Automated Kit, Windows reads the instructions from the file Autounattend.xml
March 13, 201213 yr Can you post youre file please?So far it works fine, at least for me...Of course dont forget to remove sensitive information
March 14, 201213 yr hi Etz i also have the same problem.when i select tointegrate autounattend.xml full.my image wont work .when i remove autounattend.xml it works fine.also when i use a xml from rt7lite and put into image this xml works fine.but not the one created by w7t very very bizzare.tried on both dvd and usb same results.
March 14, 201213 yr If you dont post your unattended files, no one can help you, because no one knows, what could be wrong.
March 14, 201213 yr If you don't feel comfortable posting your attended on the forum, just send it to me in a PM.
March 16, 201213 yr Author File generate in the don’t work Windows 7 Toolkit:<?xml version="1.0" encoding="utf-8"?><!--Created by Windows 7 Toolkit v1.3.0.102--><unattend xmlns="urn:schemas-microsoft-com:unattend"> <settings pass="windowsPE"> <component name="Microsoft-Windows-Setup" processorArchitecture="x86" publicKeyToken="31bf3856ad364e35" language="neutral" versionScope="nonSxS" xmlns:wcm="http://schemas.microsoft.com/WMIConfig/2002/State" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"> <UserData> <AcceptEula>true</AcceptEula> </UserData> </component> </settings> <settings pass="specialize"> <component name="Microsoft-Windows-Shell-Setup" processorArchitecture="x86" publicKeyToken="31bf3856ad364e35" language="neutral" versionScope="nonSxS" xmlns:wcm="http://schemas.microsoft.com/WMIConfig/2002/State" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"> <ProductKey>D4F6K-QK3RD-TMVMJ-BBMRX-3MBMV</ProductKey> <ComputerName>*</ComputerName> </component> <component name="Microsoft-Windows-Security-SPP-UX" processorArchitecture="x86" publicKeyToken="31bf3856ad364e35" language="neutral" versionScope="nonSxS" xmlns:wcm="http://schemas.microsoft.com/WMIConfig/2002/State" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"> <SkipAutoActivation>true</SkipAutoActivation> </component> </settings> <settings pass="oobeSystem"> <component name="Microsoft-Windows-Shell-Setup" processorArchitecture="x86" publicKeyToken="31bf3856ad364e35" language="neutral" versionScope="nonSxS" xmlns:wcm="http://schemas.microsoft.com/WMIConfig/2002/State" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"> <OEMInformation> <Model>Asus</Model> <SupportURL>http://loginvovchyk.ru/</SupportURL> <Manufacturer>Asus</Manufacturer> </OEMInformation> <OOBE> <HideEULAPage>true</HideEULAPage> <HideWirelessSetupInOOBE>true</HideWirelessSetupInOOBE> <NetworkLocation>Home</NetworkLocation> <ProtectYourPC>1</ProtectYourPC> </OOBE> <TimeZone>Russian Standard Time</TimeZone> </component> </settings></unattend>
