Many of you may already know this but it was new to me so I figured I would post it for others:
If you get this error when installing WIN7 to Virtual Box:
"Windows failed to start. A recent hardware or software change might be the cause. To fix the problem:
1. Insert your windows install disk and restart the computer.
2. Choose your language settings, and then click NEXT
3. Click repair the computer.
If you do not have the install disk contact your system administrator or computer manufacturer for assistance.
Status: 0xc0000225
Info: An unexpected error has occurred."
The cause of this problem is the APIC (Advanced Programmable Interrupt Controller), on which Windows depends. You must enable this feature in the virtual machine settings.
  • 1 year later...
To be correct, this is only required for x64 installations. For x86, you can leave I/O APIC un-checked. There is a small performance penalty for using I/O APIC, not that I've ever noticed.
good to know thanks
