Legolash2o Posted March 28, 2012 Posted March 28, 2012 This tool lets you download the latest updates which are not available via Windows Updates. This updates are know as QFE updates and are made available to those who have specific issues but everyone just integrates them anyway.Note: Previous useIf you have used this tool before then use the top browse button and select the folder you downloaded to them previously.Step 1: Select from listSelect which updates you want in the list, i.e. Windows 7 x64. If you selected a previous folder then W7T will scan and tell you which updates are new and move the old ones to a folder called 'Old'Step 2: Select UpdatesOnce selected W7T will show you a list of updates and all of the ones you don't have should be clicked.Step 3: StartPress 'Download' and watch your updates download.INFO:Some updates go into sub-folders because they only need installing if you have that specific feature installed and they're not always needed. justicegate, t0rr3nt and murriteacher 3
trial Posted February 12, 2013 Posted February 12, 2013 Win Toolkit 1.4.1.14 Update Catalog.There are 2 different sub selections "KUC" and "McRip", what does that mean?Thanks.
Legolash2o Posted February 12, 2013 Author Posted February 12, 2013 KUC and McRip are the name of the people who manage those particular servers.
KOTT2T Posted March 12, 2013 Posted March 12, 2013 Two weeks does not work server may mistake in windows ?
ricktendo Posted March 12, 2013 Posted March 12, 2013 Two weeks does not work server may mistake in windows ? Somebody needs to step up and offer a FTP for use, I am sure PointZero or somebody would be happy to maintain the hotfixes. But somebody needs to pony up first
myselfidem Posted March 12, 2013 Posted March 12, 2013 However...Strange guy Mc Rip, isn't it?: http://download.cesidian.info/finger.jpg
ricktendo Posted March 12, 2013 Posted March 12, 2013 No, that is the error page you get when you try to download a file without going thru adfly (to stop hotlinkers)
myselfidem Posted March 12, 2013 Posted March 12, 2013 (edited) Sorry but I don't think. You can try : http://download.cesidian.info/download.mcrip?f=office2013-x86.exe *Edit: I think many guys would like to see "error 404 page not found" ? Edited March 12, 2013 by myselfidem
ricktendo Posted March 12, 2013 Posted March 12, 2013 You are doing EXACTLY the thing I describe, you are HOTLINKING to the file trying to cheat McRip out of a adfly click
myselfidem Posted March 12, 2013 Posted March 12, 2013 Example download links found here: http://www.wincert.net/forum/topic/11092-update-servers-offline/#entry97048
ricktendo Posted March 12, 2013 Posted March 12, 2013 That is NOT an example, an example is adfly.com/xxxxxx link...you find that link and use it and you will be able to download the file
myselfidem Posted March 12, 2013 Posted March 12, 2013 (edited) Thanks! http://forums.mydigitallife.info/printthread.php?t=19461&pp=40&page=1 SoLoR's repository is now offline!Thank you SoLoR and Chris123NT for your hard work and commitment! Edited March 13, 2013 by myselfidem
KOTT2T Posted March 21, 2013 Posted March 21, 2013 Ура! cервер win 8x64 заработал! Hooray! Server win 8x64 working!
engine987 Posted March 30, 2013 Posted March 30, 2013 When I download all Windows updates one month, how do I know what updates have been added for the next month when I go to download new ones?I obviously don't want to download updates that I have previously downloaded.
ianymaty Posted March 30, 2013 Posted March 30, 2013 Don't change the folder where the updates are downloaded and the rest is taken care by the program. The program scans the folder and select only the missing ones to download. In the meantime it moves the superseded updates to 'Old' folder. You don't have to worry about that, you'll always have what's currently needed in the folder.
engine987 Posted March 31, 2013 Posted March 31, 2013 ianymaty,Thanks for letting me know. I tried it this morning - I selected the previous download location and the tool found one update that I did not have, so I downloaded it. However, instead of the program putting all the previous updates in a folder called "Old", it put the one new update in the "Old" folder. I don't think it was supposed to work that way and I don't think I'm doing something wrong. I could understand if it called the folder "New" and put new updates there. Any ideas what might be causing this or is it a bug - I'm using the latest version of Win Toolkit 1.4.1.22.
ianymaty Posted March 31, 2013 Posted March 31, 2013 I don't know what happend there but if it was a bug I think it was already reported since it is the most (I think) used feature from the program. Make a folder 'WTK' (or whatever you want) where always extract WinToolkit.exe and replace the old one keeping the folder and all subfolders including Updates in the same structure. Make the adjustments in the program for Update Catalog folder and keep it always the same. The program should work fine.
engine987 Posted March 31, 2013 Posted March 31, 2013 Thanks ianymaty,One more thing - in downloading the updates, I also downloaded all the "Additional" packages. When you point the all-in-one integrator to the folder with the updates and "Additional" folder, does it integrate the "Additional" items as well?
ianymaty Posted March 31, 2013 Posted March 31, 2013 See here compstuff method http://www.wincert.net/forum/topic/10955-my-personal-image-integration-process/
cometoluc Posted April 19, 2013 Posted April 19, 2013 Hello, i'm trying to add a dutch languagepack 64bit version to my 64bit windows, for some reason the languagepack does not get integrated, i tried with all updates and also with only the languagepack but no difference. I do see that the line of the languagepack is in blue color.
bphlpt Posted April 19, 2013 Posted April 19, 2013 Which exact version of Win x64 are you trying to add the languagepack to? Cheers and Regards
cometoluc Posted April 20, 2013 Posted April 20, 2013 Which exact version of Win x64 are you trying to add the languagepack to? Cheers and RegardsHello, i'm using windows 7 ultimate version
jlvoutat Posted June 17, 2013 Posted June 17, 2013 (edited) These update catalog works for win7 pro x64 SP1 (Service Pack 1)? I need these updates...KB2467173, KB2814124, KB2636927... Im not find on the update catalog! Edited June 17, 2013 by jlvoutat
