Posted March 28, 201213 yr The 'Driver Installer' lets you install any driver either from driver packs or you just have an updated driver to the computer currently installed (Live).Installing DriversStep 1: Select the folder your drivers are inUse the 'Add Drivers' to select the folder which contains your drivers *.inf filesNote: *.inf files with the same MD5 will not be added, this avoids installing the same driver.Step 2: Click StartOnce your files have been added, click 'Start' and W7T will start installing the drivers on your computer.Step 3: WaitWait may take some time to install all the drivers, so go for coffee, cup of tea or whatever you prefer. W7T will let you know when it's done.Uninstalling DriversStep 1: Press the scan buttonThis will check which drivers are already installed via on your live system.Step 2: Select the drivers you want to removeTick the boxes next to the drivers your want to remove.Step 3: Press 'Uninstall' and waitNow all you have to do is sit back and wait for those obsolete drivers to be removed, W7T will update the list once completed.
July 17, 201212 yr Hi Wincert, i am about to make a windows 7. with 32-64 together. i intergrated like all update + drivers packs 700 drivers or so. but i take like forever i am up on 24hours now. its so slow in intergrateding drivers and updates. is there a way to speed this process up. do i need faster harddrives or what can be done. its not the newest computer.and i have disable the antivirus program.Intel Quadcore Q66006 GB MemorySeagate 1000TB Disk 7200RPM.Windows 7 Pro 64BitKind regards Maxithx
July 17, 201212 yr Apparently I don't have permissions to see larger versions of your thumbnails, Lego
July 17, 201212 yr Author Apparently I don't have permissions to see larger versions of your thumbnails, Lego Neither do i
July 17, 201212 yr Yes, seems like a bug with the latest update of our board software. I will try to fix this as soon as possible.Regards,Nik
September 9, 201212 yr yes it takes about 24hours to integrate but you must remember for an AIO image you are compressing 200+Gigs with all of them drivers into a 6.x GB file it is just amazing I am shocked it could be done this soon and I'm running an AMD 1100T with 16GB of ram over clocked to 3.8GHZ per core.
February 25, 201312 yr Los drivers gráficos se integran pero no se instalan, ¿alguien sabe porqué? Muchas gracias. The graphics drivers are integrated but not installed, does anyone know why?Thank you very much. Edited February 25, 201312 yr by mooms added English translation
February 25, 201312 yr Coralco: I have edited your post to add English traduction.Thanks to post in English in this section.
February 26, 201312 yr Author I think some AMD drivers require it to be installed via the EXE with catalyst control center or whatever it's called. It's out of my control that
March 1, 201312 yr Los drivers gráficos se integran pero no se instalan, ¿alguien sabe porqué? Muchas gracias. The graphics drivers are integrated but not installed, does anyone know why? Thanks for your help. E not found any Spanish forum to resolve this question.Would be very grateful if someone could guide me to make the graphics drivers were installed, as all other drivers if integrated with Win Toolkit have been correctly installed on it.Again thank you very much Edited March 1, 201312 yr by Coracolo
January 1, 201411 yr Unknown Error X: Status: Installing Driver: I get this error for every driver I'm trying to integrate. Using the latest version 1.4.21.8. Adding them by DISM command line works but not when using the app's Driver Installer option. Ty Edited January 1, 201411 yr by kukubau
January 1, 201411 yr Dism will integrate a x86 driver into a x64 image (and vice versa) without error, the driver will still be useless. Pnputil will not
January 28, 201411 yr sir in win toolkit, there should be option to take backup of drivers of currently installed system.
January 28, 201411 yr sir all in one integrator tool, when i add folder of drivers then some of added drivers are displayed in blue color, what does this mean?
January 28, 201411 yr Blue color means that are duplicate drivers. Compare the highlited files and eliminate the duplicate drivers from list.
January 29, 201411 yr sir in driver installer tool in currently installed system, when we add folder of drivers and then these drivers are added successfully in list then there should also be option that "force to install drivers unsigned". b'z during installation many times "windows security" alert message comes that "windows can't verify the publisher of this driver softwares", to avoid this message again and again there should also be option that "force to install drivers unsigned" so that we can tick this option before installation starts
January 29, 201411 yr sir driver installer should also install the exe, zip and RAR files of drivers.
January 14, 201510 yr I have a driver.cab from dell with all drivers for my laptop model which i would like to integrate in a windows image. Can the toolkit work with this .cab file and include it in my windows image to install everything automatically? Extracting the .cab file down to the .inf files and manually including them is quite inconvenient but is the only option i can see. Please help.
January 15, 201510 yr Simply export it to a directory then, and just add the whole directory instead one by one.
January 16, 201510 yr By Export you mean Extract? If i extract with 7zip i receive about 10 levels of subdirectories with a manifest.xml file on top which i think contains information for windows how to choose the correct drivers. The .cab file contains all possible drivers for hardware variations of the dell model I have (E6540), not just the hardware that is actually installed. Also the .inf files are buried somewhere in the subfolders which contain hunderds of files each, among them .exe installers which i would have to extract as well to get down to the .inf files. I would not even know where to start. Or maybe I misunderstood your answer. Still confused on how to approach this.
May 15, 20168 yr I am trying to add new drivers for skylake and it doesn't recognize anything in my folders. It said all that was needed are .inf files which are in there. Am I missing something? I have win tool 1544 and win10 pro. This is for a Gigabyte GA-Q170M-D3H, I5-6500, and 8GB ram and windows 7 Ult x64 and RAID5. I have the Gigabyte USB 3.0 (mb_utility_windowsimagetool) driver and EZRAID as well as the RAID driver bootdisk irst 64 - 100 series for installer. Here's the problem I'm having, but RAID5 instead of NVMe. I have no optical drive. USB only.
