I used a preset for SoLoR updates and it had 336 updates
When it was loading the updates it said 336 of 350... when it started integrating it said 336
1. http://clip2net.com/s/1Kz7W
2. http://clip2net.com/s/1Kz8j
The 350 is the amount of Updates + the amount of 'Options' ticked.
i.e. 336 updates and 14 Options :)
EDIT: Simply put... it's the amount of lines in the preset text file. For example if you have 100 updates, 100 drivers and 10 settings it would say x of 220 :)
Edited by Legolash2o
