Posted (edited)
Hi,
when I want to integrate IE9 language pack, it turns red after integration and then its not showed as integrated after toolkit finishes all tasks. Is that ok, will it work ? Im trying to do my new Win 7 Image, but as you releasing new versions every 5 minutes, Im doing it for 5th time now.
Edited by Icydead
Posted (edited)
It's quite a new feature so just ignore the red on that particular update :) It'll be fixed in the next version.
EDIT: Fixed.
Edited by Legolash2o
