komitaltrade Posted March 30, 2012 Posted March 30, 2012 As you published 4 versions in 2 days, I guess how you should to realised how following your work is not easy.Please consider next idea.Im using Ketarin (https://ketarin.org) to automatically keep packages up to date.Try to open Dropbox free account (public folder) and publish clean exe file (not rar or zip) on it like alternative link (it is easy way to set it in Ketarin) or find any other option and build template for Ketarin how to follow up to date of the W7T. Quote
Legolash2o Posted March 30, 2012 Posted March 30, 2012 I dont usually release this many updates, it mostly because its an initial release Quote
komitaltrade Posted March 31, 2012 Author Posted March 31, 2012 I dont usually release this many updates, it mostly because its an initial release OK, but I think how you can considering idea.P.S: It looks like again appear problem with language integration (again more than hour and 20 minutes just for one language integration, no updates, tweaks, etc.).When you wrote how issue is solved, it was solved, so, see what is going on again. Quote
Legolash2o Posted June 6, 2012 Posted June 6, 2012 I have an agreement to use Wincert as the main download source, and i can't imagine ketarin working with the wincerts 'Download' tab section. Quote
