Yes, are native and bootables, I choose USB drive from Menu by press F8 at BIOS boot...
you're lucky then... or maybe Asus has done their homeworks better. On a Gigabyte with USB 3.0 by Renesas those ports aren't usable with bootable sticks. :(
Edited by RicaNeaga
What's your Gigabyte motherboard model...?
sorry, I thought it was ontopic - talking about booting from usb 3.0 ports.
alfreire, Gigabyte GA-890FXA-UD5 is my motherboard. We'll (please) continue via pm if you have other things to add. :)
The problem is still the same :(
Exact error message:
A necessary CD-/DVD-Driver is missing. If you have a driver disk -CD, -DVD or a USB-Flashdrive, please insert it now.
As I said the driver worked before, at least when I choose it manually then, was no problem.
So the issue is not boot.wim related, it must be any option in WinKit that causes this.
Any tweak, option I dunno :(
Ahhhhhhhhhhh!!!! :ranting: :ranting: :ranting: Seems it won't work again.
Made again a new Image and integrated only the drivers, no more changes.
The drivers appeared in the Windows 7 Pro x64 and in the Windows Setup section.
But no chance...
Also trying again to search for it manually was no success.
I don't understand that. I mean this are the right drivers.
Last time I had this problem it was any fault in the options of Winkit, I loaded older preferences and everything was ok. But this time I even did not do any changes so WTF.
This is driving me insane :aggressive:
Edited by ThaNiTeHawK
Guys, you won't believe... :shifty:
It seems that this fracking PCI-E SSD needs another HDD that the drivers can be used. :doh:
That makes abolutely no sense but after I added the driver for my SATA Chipset the driver for the SSD could be used.
Before I had this additional HDD on a SATA port which did not need drivers for the Windows Setup.
But also again it only worked after I choose it manually. Before this switch of my other HDD to the other SATA ports the integrated one worked.
Is anybody of you aware of such an issue??
