ENU_user Posted April 5, 2012 Posted April 5, 2012 I get an error when I try to load the dvd source"this seems to be an *swm file which is read-only and not supported by W7T you need to to merge this back into *.wim file first.."Exception:Microsoft Windows XP [Version 5.1.2600]© Copyright 1985-2001 Microsoft Corp.M:\win7\install\lang>Set SEE_MASK_NOZONECHECKS=1M:\win7\install\lang>imagex /Info "M:\win7\w7_sp1-X17-59183\SOURCES\install.wim"M:\win7\install\lang>exitthen tried using the *swm merger tool to try and locate the *swm and ther are no *swm files to begin withwhen tried using the language file converter tool picked up "windows6.1-kb2483139-x86-he-il.exe"choosing destination for the converted file.."I get :the system cannot find the file specified "command line" = "exe2cab "*.exe" "*.cab""btw would it be possible for you to add the "iso creator" to the all-in-one tool and by so making it easier posibly so far with all my modding attempts I have not succeeded seeing anything happen or changed, i ran the AIO tool made an ISO and tested on VM..after starting all in one loaded from a preset the tool asks what to do.. when I choose to "save the image before trying to make an iso I receive "error trying to commit image"besides that I haven't noticed anything getting applied with the unattended xml file where I kept in the root of the built ISO-DVDI am using a Win7SP1 version downloaded from a link handed by the toolcontents of mount log[3680] OpenFilterPort:(326): The service cannot be started, either because it is disabled or because it has no enabled devices associated with it.[3680] FltCommVerifyFilterPresent:(630): The service cannot be started, either because it is disabled or because it has no enabled devices associated with it.[3680] WIMMountImageHandle:(764): The service cannot be started, either because it is disabled or because it has no enabled devices associated with it.[3680] StateStoreRemoveMountedImage:(1041): The system cannot find the file specified.[3680] WIMMountImageHandle:(987): The system cannot find the file specified.[6860] FIOReadFileIntoBuffer:(1468): The system cannot find the file specified.[6860] UnmarshallImageHandleFromDirectory:(432): The specified directory is not a valid mounted directory.[6860] WIMGetMountedImageHandle:(2427): The specified directory is not a valid mounted directory. Quote
Legolash2o Posted April 5, 2012 Posted April 5, 2012 (edited) I will look at the language conversion problem later, that last error log is very common on Windows XP, and usually means DISM/WIMGAPI is not installed properly. Edited April 5, 2012 by Legolash2o Quote
