paddy1 Posted April 5, 2012 Posted April 5, 2012 im running windows 7 with service pack 1 and all windows updates intergrated in to the install.wimi downwloaded W7t Vs 1.4.0.? when i used it to add the tweaks to the .wim and did a fresh install i get half way threw the install and the system reboot's the completing installation screen appears as normalbut after 2 seconds i get a blue screen error pop up and system reboots thus install has failed and im stuck in a reboot loopif i reformat the paration i was installing to i can still reinstall again so the hd is finei ran W7t Vs 1.3.0.98 and it worked finehas any one else had this problem ??is there's a bug in W7t Vs 1.4.0.? after tweaks been added ???or did i use a tweak option that caused this to happen ?? :help:below are the tweaks option i used in W7t Vs 1.4.0.?*AIO#TweaksAdd 'Copy To Folder' to context-menuAdd 'Move To Folder' to context-menuAdd 'Task Manager' to desktop context-menuRemove 'Print' from context-menuRemove 'Troubleshoot Compatiblity' from context-menuSmall Taskbar IconsUnlock the taskbarAllow 3rd Party ThemesChange DPI Setting::Medium 125%Control Panel View::Small IconsDisable 8.3 Name CreationDisable Language BarDisable Last File Access TimestampDisable Low Disk Space NotificationDisable Search Online on Unknown File ExtensionsDisable Shortcut Link ResolveDisable Thumbnail CacheIncrease Icon CacheRemove Shortcut PrefixShow All Icons on System TrayShow Hidden Files & FoldersSpeed Up DesktopSpeed-up Access to AVI Media FilesDisable Auto Reboot after installing updatesDisable Windows Media Player AutoUpdatesOpen NFO files with notepadRemove Windows Mail SplashShow Notepad StatusbarWord Wrap in NotepadDisable Default Browser CheckDisable First Run CustomizeDisable IE Crash DetectionDisable Internet Explorer to Check for UpdatesDisable Password Caching in Internet ExplorerDisable Signature checking for EXEsDisable Warning on Close (Tabs)Enable Third Party ComponentsReset Text Size(New Tabs)Reset Zoom Level (New Tabs)Set Google as Search ProviderTurn Off RSS feed discoveryUnlimited Simultaneous DownloadsDisable Highlighting of new ProgramsRemove 'Default Programs' from Start MenuRemove 'Devices & Printers' from Start MenuRemove 'Help & Support' from Start MenuRemove 'Music' from Start MenuRemove 'Videos' from Start MenuShow 'Downloads' on Start MenuShow 'Run' on Start MenuUse small icons on Start MenuDetailed Shutdown & LogonDisable Group Policy SynchroniseEnable Boot DefragEnable MSI Service in Safe ModeShutdown QuickerAlways Unload DLLDisable Admin SharesDisable Auto System Sounds Leveling::Reduce all other by 50%Disable Bandwidth LimitDisable Dr WatsonDisable HibernationDisable NTFS EncryptionDisable Windows Error ReportingDon’t allow Windows to turn off devicesImprove USB Storage Devices PerformanceIncrease File System Memory Cache SizeIncrease RPC Packet SizeCustom 1 (MANIKANT.S.GUPTA) Quote
Legolash2o Posted April 5, 2012 Posted April 5, 2012 Does it work without the tweaks set? Sometimes updates cause a BSOD. Quote
