InstallFonts Tool
InstallFontsTool x86
tabdownload.png Update (24 October 2013)
Hash MD5 BDB73A5921AB06BD9F6C3B56A46C218D
Filesize: 412 KB (421888 bytes)
InstallFontsTool x64
Hash MD5 D41D375A2EC052250FAEDD6DFC194CC1
Filesize: 444 KB (455168 bytes)
This tool allows you to easily install in your Windows NT6.x image (Vista/7/8/8.1) in unattended mode your personal fonts
Regline examples:
"InstallFontsTool.exe" "lokicola.ttf" "Loki Cola (TrueType)"
"InstallFontsTool.exe" "*.ttf"
With the following command line the tool searches for font files in FontDir directory and all subdirectories:
"InstallFontsTool.exe" "FontDir"
All file and directory path shown in command line must be present in same directory of InstallFontsTool.exe, as it serches for "File\Folder" inside its working directory. Otherwise you must use a command like this:
"InstallFontsTool.exe" "%UserProfile%\Desktop\FontDir"
or
"InstallFontsTool.exe" "%UserProfile%\Desktop\lokicola\lokicola.ttf"
Source code:
#RequireAdminGlobal Const $HWND_BROADCAST = 0xFFFFGlobal Const $WM_FONTCHANGE = 0x1DGlobal $aRet, $hGdi32 = DllOpen("gdi32.dll")Global $SourceFile, $FontDescript, $sDir, $sFilter, $aDirFilter;_InstallFontEx(@DesktopDir & "\SourceCodePro-ExtraLight.otf");_InstallFontEx(@DesktopDir & "\lokicola\lokicola.ttf", "Loki Cola (TrueType)")If $CmdLine[0] > 0 Then   For $Count = 1 To $CmdLine[0]      $sDir = $CmdLine[$Count]      If StringInStr($sDir, "*", 1) Then         $sFilter = StringRegExpReplace($sDir, ".*[\/\\]+", "")         $aDirFilter = StringRegExp($sDir, "(.+[^\/\\])([^\/\\]+)", 1)         If Not @Error Then            $sDir = $aDirFilter[0]            $sFilter = $aDirFilter[1]            If Not StringRegExp($aDirFilter[0], "^\h*(?:\\\\\?\\)*(\\\\[^\?\/\\]+|[A-Za-z]:)") Then $sDir = @ScriptDir & "\" & $aDirFilter[0]         Else            $sDir = @ScriptDir         EndIf         $SourceFile = _FileListToArrayEx($sDir, $sFilter, 13)         If Not @Error Then            For $y = 1 To $SourceFile[0]               _InstallFontEx($SourceFile[$y])            Next         EndIf      Else         If Not StringRegExp($sDir, "^\h*(?:\\\\\?\\)*(\\\\[^\?\/\\]+|[A-Za-z]:)") Then $sDir = @ScriptDir & "\" & $CmdLine[$Count]         If StringInStr(FileGetAttrib($sDir), "D", 1) Then            $SourceFile = _FileListToArrayEx($sDir, "(?:\.fon$|\.ttf$|\.ttc$|\.fot$|\.otf$|\.mmm$|\.pfb$|\.pfm$|\.pfb$)", 77)            If Not @Error Then               For $y = 1 To $SourceFile[0]                  _InstallFontEx($SourceFile[$y])               Next            EndIf         Else            If $CmdLine[0] > $Count And StringRegExp($CmdLine[$Count + 1], "\(.+\)") Then               $FontDescript = $CmdLine[$Count + 1]               $Count += 1            EndIf            _InstallFontEx($sDir, $FontDescript)         EndIf      EndIf   NextElse   MsgBox(0, "Error", "Please drop files to this script to run it!" & @LF & 'example : InstallFontsTool.exe "FontsName.ttf" "Fonts Desc"')EndIfDllClose($hGdi32); #FUNCTION# ====================================================================================================================; Name...........: _InstallFontEx; Description ...: Install a Font file; Syntax.........: _InstallFontEx($sFilePath); Parameters ....: $sFilePath     - The full path file;                  $sFontDescript - Optional, Font Description;                  $sFontsPath    - Optional, Font Path Destination; Return values .: Success - Title Property; Author ........: DXRW4E; ===============================================================================================================================Func _InstallFontEx($sFilePath, $sFontDescript = "", $sFontsPath = "")    If Not $sFontsPath Then $sFontsPath = @WindowsDir & "\Fonts"   Local $sFontsName = StringRegExpReplace($sFilePath, "\A.+[\/\\]+", "")    If Not FileCopy($sFilePath, $sFontsPath & "\" & $sFontsName, 1) Then Return SetError(1, 0, 0)   $aGdi32 = DllCall($hGdi32, "Int", "AddFontResource", "str", $sFontsPath & "\" & $sFontsName)   If @Error Or Not $aGdi32[0] Then Return SetError(1, 0, 0)   If Not $sFontDescript Then      ;;$aGdi32 = DllCall($hGdi32, "int", "GetFontResourceInfoW", "wstr", $sFontsPath & "\" & $sFontsName, "dword*", 4096, "wstr", "", "dword", 1)      ;;$sFontDescript = $aGdi32[3] & _FontGetProperty($sFilePath, 1)      $sFontDescript &= _FontGetProperty($sFilePath)   EndIf   RegWrite("HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Fonts", $sFontDescript, "REG_SZ", $sFontsName)    DllCall("user32.dll", "Int", "SendMessage", "hwnd", $HWND_BROADCAST, "int", $WM_FONTCHANGE, "int", 0, "int", 0)    Return 1EndFunc; #FUNCTION# ====================================================================================================================; Name...........: _FontGetProperty; Description ...: Returns a property for a Font file; Syntax.........: _FontGetProperty($sFilePath); Parameters ....: $sFilePath  - The full path file; Return values .: Success - Title Property; Author ........: DXRW4E; ===============================================================================================================================Func _FontGetProperty($sFilePath, $iFlags = 0)    ;$sFilePath = StringRegExpReplace($sFilePath, '["' & "]", "")    If Not FileExists($sFilePath) Then Return SetError(1, 0, "")    Local $sTitle, $objFolder, $objFolderItem, $objShell = ObjCreate("Shell.Application")    If @Error Then Return SetError(3, 0, "")   $objFolder = $objShell.NameSpace(StringRegExpReplace($sFilePath, "\A.+\K[\/\\][^\/\\]*$", ""))    $objFolderItem = $objFolder.Parsename(StringRegExpReplace($sFilePath, "\A.+[\/\\]+", ""))   If Not $iFlags Then      $sTitle = $objFolder.GetDetailsOf($objFolderItem, 21)      If Not $sTitle Then Return SetError(2, 0, 0)   EndIf   If StringRegExp($objFolder.GetDetailsOf($objFolderItem, 187), "(?:True|Open)Type") Then $sTitle &= " (TrueType)"    Return $sTitleEndFunc   ;==>_FontGetProperty; #FUNCTION# =======================================================================================================================================================; Name...........: _FileListToArrayEx; Description ...: Lists files and\or folders in a specified path (Similar to using Dir with the /B Switch); Syntax.........: _FileListToArrayEx($sPath[, $sFilter = "*"[, $iFlag = 0]]); Parameters ....: $sPath   - Path to generate filelist for.;                  $sFilter - Optional the filter to use, default is *. (Multiple filter groups such as "All "*.png|*.jpg|*.bmp") Search the Autoit3 helpfile for the word "WildCards" For details.;                  $iFlag   - Optional: specifies whether to return files folders or both Or Full Path (add the flags together for multiple operations):;                  |$iFlag = 0 (Default) Return both files and folders;                  |$iFlag = 1 Return files only;                  |$iFlag = 2 Return Folders only;                  |$iFlag = 4 Search SubDirectory;                  |$iFlag = 8 Return Full Path;                  |$iFlag = 16 $sFilter do Case-Sensitive matching (By Default $sFilter do Case-Insensitive matching);                  |$iFlag = 32 Disable the return the count in the first element - effectively makes the array 0-based (must use UBound() to get the size in this case).;                    By Default the first element ($array[0]) contains the number of file found, the remaining elements ($array[1], $array[2], etc.);                  |$iFlag = 64 $sFilter is REGEXP Mod, See Pattern Parameters in StringRegExp (Can not be combined with flag 16);                  |$iFlag = 128 Return Backslash at the beginning of the file name, example Return "\Filename1.xxx" (Can not be combined with flag 8); Return values .: Failure - @Error;                  |1 = Path not found or invalid;                  |2 = Invalid $sFilter;                  |3 = No File(s) Found; Author ........: DXRW4E; Modified.......:; Remarks .......: The array returned is one-dimensional and is made up as follows:;                                $array[0] = Number of Files\Folders returned;                                $array[1] = 1st File\Folder;                                $array[2] = 2nd File\Folder;                                $array[3] = 3rd File\Folder;                                $array[n] = nth File\Folder; Related .......:; Link ..........:; Example .......: Yes; Note ..........: Special Thanks to SolidSnake & Tlem; ==================================================================================================================================================================Func _FileListToArrayEx($sPath, $sFilter = "*", $iFlag = 0)    $sPath = StringRegExpReplace($sPath & "\", "(?!\A)[\\/]+\h*", "\\")    If Not FileExists($sPath) Then Return SetError(1, 1, "")   If StringRegExp($sFilter, StringReplace('^\s*$|\v|[\\/:><"]|^\||\|\||\|$', "[" & Chr(BitAND($iFlag, 64) + 28) & '\/:><"]|^\||\|\||\|$', "\\\\")) Then Return SetError(2, 2, "")   Local $hSearch, $sFile, $sFileList, $sSubDir = BitAND($iFlag, 4), $sDelim = "|", $sDirFilter = StringReplace($sFilter, "*", "")    $hSearch = FileFindFirstFile($sPath & "*")    If @Error Then Return SetError(3, 3, "")   Local $hWSearch = $hSearch, $hWSTMP, $SearchWD, $Extended, $iFlags = StringReplace(BitAND($iFlag, 1) + BitAND($iFlag, 2), "3", "0")   If BitAND($iFlag, 8) Then $sDelim &= $sPath   If BitAND($iFlag, 128) Then $sDelim = "|\"   If Not BitAND($iFlag, 64) Then $sFilter = StringRegExpReplace(BitAND($iFlag, 16) & "(?i)(", "16\(\?\i\)|\d+", "") & StringRegExpReplace(StringRegExpReplace(StringRegExpReplace(StringRegExpReplace($sFilter, "[^*?|]+", "\\Q$0\\E"), "\\E(?=\||$)", "$0\$"), "(?<=^|\|)\\Q", "^$0"), "\*+", ".*") & ")"   While 1        $sFile = FileFindNextFile($hWSearch)        If @Error Then            If $hWSearch = $hSearch Then ExitLoop            FileClose($hWSearch)            $hWSearch -= 1            $SearchWD = StringLeft($SearchWD, StringInStr($SearchWD, "\", 1, -2))        ElseIf $sSubDir Then            $Extended = @Extended            If ($iFlags + $Extended <> 2) Then                If $sDirFilter Then                    If StringRegExp($sFile, $sFilter) Then $sFileList &= $sDelim & $SearchWD & $sFile                Else                    $sFileList &= $sDelim & $SearchWD & $sFile                EndIf            EndIf            If Not $Extended Then ContinueLoop            $hWSTMP = FileFindFirstFile($sPath & $SearchWD & $sFile & "\*")            If $hWSTMP = -1 Then ContinueLoop            $hWSearch = $hWSTMP            $SearchWD &= $sFile & "\"        Else            If ($iFlags + @Extended = 2) Or StringRegExp($sFile, $sFilter) = 0 Then ContinueLoop            $sFileList &= $sDelim & $sFile        EndIf    WEnd    FileClose($hSearch)    If Not $sFileList Then Return SetError(3, 3, "")   Return StringSplit(StringTrimLeft($sFileList, 1), "|", StringReplace(BitAND($iFlag, 32), "32", 2))EndFunc   ;==>_FileListToArrayEx
  • 1 year later...
