Posted April 24, 201212 yr hi lego when using the msu-cab converter if you import more than 180 hotfixes at a time it crashes.says winkit encountered error.yet version 1.4 15 works fine i can import 400 hotfixes no issues at all. :g:also i used tweaks,updates and silent installes in aio tool and everything bar silent installs worked.ie tweaks were applied and updates were integrated but silent installs wasn,t and apply unattend full also didnt work.silent installs worked fine for me in version 1.4.0 15 Edited April 24, 201212 yr by reptileodeath
May 29, 201212 yr I haven't been able to solve the MSU to CAB Converter bug mostly because I can't replicate, just make sure not to delete any of the DLLs which get created when opening W7T.The silent installer issue has been fixed in v19.
