Posted April 26, 201213 yr Hi.Which is the best way to do this, should i delete windows default drivers first then intergrate my own or is it the other way round?RegardsWorf.
May 29, 201212 yr I think the only time it matters is when you're integrating updates and removing features/components (i.e. vLite). You will have to integrate updates first. With drivers it does not matter.
