Etz Posted May 1, 2012 Share Posted May 1, 2012 (edited) 1. Setup background change tweak doesnt work, it doesnt get changed2. None of Silent installers seem to work, they do get copied onto "DVDroot", Apps folder, but they wont install. In fact Installer WTK wont launch at all.3. Themepacks do integrate, but show blank icons under personalize.4. Sometimes mounting image fails with an error: "An attempt was made to load a program with an incorrect format."Will try to dig deeper, to find whats causing those problems to get some more useful information They worked on earlier versions vithout problems, so theres must be some changes that broke those. Edited May 9, 2012 by Legolash2o Link to comment Share on other sites More sharing options...
Kelsenellenelvian Posted May 1, 2012 Share Posted May 1, 2012 Thanks to oguz being so rude as to open YET ANOTHER thread on this issue this one is now outdated and being closed... Link to comment Share on other sites More sharing options...
