If I have a fully functional WIN7 integration and as an example a new version of a particular item comes out... lets say java v7.4 can I just replace the original SFX file java v7.3 in the Apps folder of my integration and burn a new DVD?
Thanks for the response and ironically last night I ran a test and can confirm that this did work for me... I went from a Java 6 SFX to a Java 7 SFX and it worked like a charm.
Yes, if you created the new Java7u4.exe (SFX) yourself or already made!
Regards
