AIDA64 Extreme v4.70.3200
Features: Added Control Panel icon option during install, Desktop icon unchecked by default, Quick Launch icon unchecked/only offered to Vista and bellow, Sidebar Gadget installs by default on Vista or 7 (not 8,) for program registration setup will copy pkey.txt if present in the same directory as the installer, removed languages and files (details bellow)
Download: http://adf.ly/1713566/aida64ext
MD5: ca70ea56143785d303f7acf9a2b71b35
Website: http://www.aida64.com/product/aida64-extreme/overview
Removed:
***TOOLBARS***aida64.webkerneld.ia64kerneld.w9xlibeay32.dll (will require OpenSSL)ssleay32.dll (will require OpenSSL)(Installs only on x64)aida_bench64.dllaida_helper64.dllkerneld.x64(Languages removed)lang_aa.txtlang_al.txtlang_bg.txtlang_bs.txtlang_by.txtlang_ca.txtlang_cn.txtlang_cz.txtlang_de.txtlang_dk.txtlang_ee.txtlang_es.txtlang_fi.txtlang_fr.txtlang_hr.txtlang_hu.txtlang_id.txtlang_it.txtlang_jp.txtlang_kr.txtlang_lt.txtlang_lv.txtlang_mk.txtlang_nl.txtlang_no.txtlang_pl.txtlang_pt.txtlang_ro.txtlang_ru.txtlang_se.txtlang_si.txtlang_sk.txtlang_src.txtlang_srl.txtlang_tr.txtlang_tw.txtlang_ua.txt
Nope, its much! simpler...read the "Features" carefully
(for program registration) setup will copy pkey.txt if present in the same directory as the installer
You will find pkey.txt in the program files folder after you register the program, back it up somewhere so next time you do a install you only need to put it in the same dir as this installer and it will be copied/registered automatically
Edit: BTW minor installer update, fixed installer file version info (nothing major only cosmetic)
In latest version which I installed it didn't copy any pkey.txt file....
I just tested and it worked fine here.
Are you sure you have pkey.txt in the same dir as the installer and are you sure it was not the original installer you were using?
  • 4 months later...
The languages are back and they are set for conditional install, depending on what language you select ONLY that language will install and will also set it as the default program language
English NO languages are installed
  • 3 months later...
