About: This is the business version of Skype MSI so by default it has no junk!
Tweaked: Shortcut moved out of sub folder into All Programs, Run on Windows startup removed, Run after standard GUI install removed
Differences between Skype installers:
  Quote
x.xx.0.xxx - normal installer
x.xx.1.xxx - affiliate installer provides services [Taiwan's PChome]
x.xx.10.xxx - affiliate installer [Hong Kong company HGC]
x.xx.11.xxx - affiliate installer [Polish company Onet]
x.xx.24.xxx - affiliate installer [a UK social networking site Bebo]
x.xx.32.xxx - Business installer more convenient for centralized deployment in networks
x.xx.56.xxx - affiliate installer [Taiwan's PChome]
x.xx.59.xxx - online installer, or as a program, updated through
x.xx.63.xxx - affiliate installer [ukrainian Privatbank]
x.xx.64.xxx - UI version - version with a new user interface
x.xx.65.xxx - affiliate installer [Korean company Daesung]
x.xx.66.xxx - affiliate installer [Yandex]
x.xx.67.xxx - affiliate installer offers to install the homepage Yandex search and services;
x.xx.73.xxx - version with support for Windows Live Messenger
x.xx.74.xxx - version with support for Windows Live Messenger
x.xx.80.xxx - affiliate installer [the Japanese company Excite]
x.xx.81.xxx - UI version - version with a new user interface
x.xx.85.xxx - UI version - version with a new user interface, officially announced Microsoft;
x.xx.99.xxx - installer strategic partner of Skype in China, the company GMF
VBS Editor Script
Option Explicit
Dim ws, installer, fs, db, view, record, x
Set ws = WScript.CreateObject("WScript.Shell")
Set fs = CreateObject("Scripting.FileSystemObject")
Set installer = WScript.CreateObject("WindowsInstaller.Installer")
If WScript.Arguments.Count <> 0 Then
	For each x in WScript.Arguments
		ProcessMSI x
	Next
Else
	If fs.FileExists("SkypeSetup.msi") Then ProcessMSI "SkypeSetup.msi"
End If
'** Function; Query MSI database                                     **
Function 	QueryDatabase(arrOpts)
	On Error Resume Next
	Dim query, file, binary : binary = false
	If LCase(TypeName(arrOpts)) = "string" Then
		query = arrOpts
	Else
		If fs.FileExists(arrOpts(0)) Then
			file = arrOpts(0)
			query = arrOpts(1)
		Else
			query = arrOpts(0)
			file = arrOpts(1)
		End If
		binary = true
	End If
	WScript.Echo query
	If binary Then
		Set record = installer.CreateRecord(1)
		record.SetStream 1, file
	End If
	Set view = db.OpenView (query) : CheckError
	If binary Then
		view.Execute record : CheckError
	Else
		view.Execute : CheckError
	End If
	view.close
	Set view = nothing
	If binary Then Set record = nothing
	binary = false
	db.commit : CheckError
End Function
'** Subroutine; Check errors in most recently executed MSI command   **
Sub CheckError
	Dim message, errRec
	If Err = 0 Then Exit Sub
	message = Err.Source & " " & Hex(Err) & ": " & Err.Description
	If Not installer Is Nothing Then
		Set errRec = installer.LastErrorRecord
		If Not errRec Is Nothing Then message = message & vbNewLine & errRec.FormatText
	End If
	Wscript.Echo "" : Wscript.Echo message : Wscript.Echo ""
	Wscript.Quit 2
End Sub
'** Function; Push changes to MSI                                    **
Function ProcessMSI(file)
	Set db = installer.OpenDatabase(file, 1)
	QueryDatabase("DELETE FROM `AdminExecuteSequence` WHERE `Action` = 'SystemFolder_x86_VC.194841A2_D0F2_3B96_9F71_05BA91BEA0FA'")
	QueryDatabase("DELETE FROM `AdminUISequence` WHERE `Action` = 'SystemFolder_x86_VC.194841A2_D0F2_3B96_9F71_05BA91BEA0FA'")
	QueryDatabase("DELETE FROM `AdvtExecuteSequence` WHERE `Action` = 'SystemFolder_x86_VC.194841A2_D0F2_3B96_9F71_05BA91BEA0FA'")
	QueryDatabase("DELETE FROM `Component` WHERE `Directory_` = 'SystemFolder_x86_VC.194841A2_D0F2_3B96_9F71_05BA91BEA0FA'")
	QueryDatabase("DELETE FROM `Component` WHERE `Directory_` = 'UpdaterFolder'")
	QueryDatabase("DELETE FROM `CustomAction` WHERE `Action` = 'SkypeStart1'")
	QueryDatabase("DELETE FROM `CustomAction` WHERE `Action` = 'SkypeStart2'")
	QueryDatabase("DELETE FROM `CustomAction` WHERE `Action` = 'SkypeUpdaterCleanup'")
	QueryDatabase("DELETE FROM `CustomAction` WHERE `Action` = 'SkypeUpdaterConfig'")
	QueryDatabase("DELETE FROM `CustomAction` WHERE `Action` = 'SystemFolder_x86_VC.194841A2_D0F2_3B96_9F71_05BA91BEA0FA'")
	QueryDatabase("DELETE FROM `Directory` WHERE `Directory` = 'SystemFolder'")
	QueryDatabase("DELETE FROM `Directory` WHERE `Directory` = 'SystemFolder_x86_VC.194841A2_D0F2_3B96_9F71_05BA91BEA0FA'")
	QueryDatabase("DELETE FROM `Directory` WHERE `Directory` = 'UpdaterFolder'")
	QueryDatabase("DELETE FROM `Feature` WHERE `Feature` = 'Updater'")
	QueryDatabase("DELETE FROM `FeatureComponents` WHERE `Component_` = 'C_CENTRAL_msvcp120_x86.194841A2_D0F2_3B96_9F71_05BA91BEA0FA'")
	QueryDatabase("DELETE FROM `FeatureComponents` WHERE `Component_` = 'C_CENTRAL_msvcr120_x86.194841A2_D0F2_3B96_9F71_05BA91BEA0FA'")
	QueryDatabase("DELETE FROM `FeatureComponents` WHERE `Component_` = 'C_CENTRAL_vccorlib120_x86.194841A2_D0F2_3B96_9F71_05BA91BEA0FA'")
	QueryDatabase("DELETE FROM `FeatureComponents` WHERE `Feature_` = 'Updater'")
	QueryDatabase("DELETE FROM `File` WHERE `Component_` = 'C_CENTRAL_msvcp120_x86.194841A2_D0F2_3B96_9F71_05BA91BEA0FA'")
	QueryDatabase("DELETE FROM `File` WHERE `Component_` = 'C_CENTRAL_msvcr120_x86.194841A2_D0F2_3B96_9F71_05BA91BEA0FA'")
	QueryDatabase("DELETE FROM `File` WHERE `Component_` = 'C_CENTRAL_vccorlib120_x86.194841A2_D0F2_3B96_9F71_05BA91BEA0FA'")
	QueryDatabase("DELETE FROM `File` WHERE `Component_` = 'SkypeUpdater'")
	QueryDatabase("DELETE FROM `InstallExecuteSequence` WHERE `Action` = 'DeleteServices'")
	QueryDatabase("DELETE FROM `InstallExecuteSequence` WHERE `Action` = 'InstallServices'")
	QueryDatabase("DELETE FROM `InstallExecuteSequence` WHERE `Action` = 'SkypeUpdaterCleanup'")
	QueryDatabase("DELETE FROM `InstallExecuteSequence` WHERE `Action` = 'SkypeUpdaterConfig'")
	QueryDatabase("DELETE FROM `InstallExecuteSequence` WHERE `Action` = 'StartServices'")
	QueryDatabase("DELETE FROM `InstallExecuteSequence` WHERE `Action` = 'StopServices'")
	QueryDatabase("DELETE FROM `InstallExecuteSequence` WHERE `Action` = 'SystemFolder_x86_VC.194841A2_D0F2_3B96_9F71_05BA91BEA0FA'")
	QueryDatabase("DELETE FROM `InstallUISequence` WHERE `Action` = 'SystemFolder_x86_VC.194841A2_D0F2_3B96_9F71_05BA91BEA0FA'")
	QueryDatabase("DELETE FROM `InstallExecuteSequence` WHERE `Action` = 'SkypeStart1'")
	QueryDatabase("DELETE FROM `InstallExecuteSequence` WHERE `Action` = 'SkypeStart2'")
	QueryDatabase("DELETE FROM `ModuleComponents` WHERE `Component` = 'C_CENTRAL_msvcp120_x86.194841A2_D0F2_3B96_9F71_05BA91BEA0FA'")
	QueryDatabase("DELETE FROM `ModuleComponents` WHERE `Component` = 'C_CENTRAL_msvcr120_x86.194841A2_D0F2_3B96_9F71_05BA91BEA0FA'")
	QueryDatabase("DELETE FROM `ModuleComponents` WHERE `Component` = 'C_CENTRAL_vccorlib120_x86.194841A2_D0F2_3B96_9F71_05BA91BEA0FA'")
	QueryDatabase("DELETE FROM `ModuleSignature` WHERE `ModuleID` = 'Microsoft_VC120_CRT_x86.194841A2_D0F2_3B96_9F71_05BA91BEA0FA'")
	QueryDatabase("DELETE FROM `MsiShortcutProperty` WHERE `Shortcut_` = 'SkypeDesktopShortcut'")
	QueryDatabase("DELETE FROM `Property` WHERE `Value` = 'DirectoryTable'")
	QueryDatabase("DELETE FROM `Registry` WHERE `Component_` = 'SkypeUpdater'")
'	QueryDatabase("DELETE FROM `Registry` WHERE `Key` = 'Software\Microsoft\Windows\CurrentVersion\Run'")
'	QueryDatabase("DELETE FROM `ServiceControl`")
'	QueryDatabase("DELETE FROM `ServiceInstall`")
	QueryDatabase("DELETE FROM `Shortcut` WHERE `Shortcut` = 'SkypeDesktopShortcut'")
	QueryDatabase("INSERT INTO `Component` (`Component`,`ComponentId`,`Directory_`,`Attributes`,`Condition`,`KeyPath`) VALUES ('SkypeRegistryRun','{7D53301D-E4F0-403A-9A1C-876F1544939E}','PhoneFolder','4','RUN = 1','reg08D3E7E5CD85CB55680CCDE42A2E2625')")
	QueryDatabase("INSERT INTO `Control` (`Dialog_`,`Control`,`Type`,`X`,`Y`,`Width`,`Height`,`Attributes`,`Property`,`Text`,`Control_Next`) VALUES ('InstallDirDlg','Run','CheckBox','20','140','370','18','19','RUN','&Start Skype when I start Windows','Next')")
	QueryDatabase("INSERT INTO `FeatureComponents` (`Feature_`,`Component_`) VALUES ('Phone','SkypeRegistryRun')")
	QueryDatabase("INSERT INTO `Property` (`Property`,`Value`) VALUES ('LicenseAccepted','1')")
	QueryDatabase("UPDATE `Shortcut` SET Directory_ = 'ProgramMenuFolder' WHERE `Directory_` = 'ProgramMenuDir'")
	QueryDatabase("UPDATE `Registry` SET Component_ = 'SkypeRegistryRun' WHERE `Registry` = 'reg08D3E7E5CD85CB55680CCDE42A2E2625'")
	QueryDatabase("UPDATE `Control` SET Control_Next = 'Run' WHERE `Control` = 'ChangeFolder'")
	Set db = nothing
End Function
  • Replies 187
  • Views 89.4k
  • ricktendo
    ricktendo
    Updated, also added option to start with windows option to installer (default is disabled, commandline is RUN=1 to enable)
  • Updated
  • Sorry for the delays lately, been busy with work... Updated skype installer Also posted the vbs I use for editing so others can do it themselves if they please. This is only for business MSI but coul
Guys - English thread?
Balbis - Release version 6.0.60.126
ricktendo64 - I think you're wrong
Balbis - Was looking for a program and I found it by chance http://skype.softonic.com/ (do not know if it's true or not)
ricktendo64 - No, the number 32 never changes (indicates the x86)
Edited by bphlpt
  • 4 weeks later...
