  • Replies 164
  • Views 59.1k
  • niTe_RiDeR_Pr0
    niTe_RiDeR_Pr0
    It's easy. let me tell you what I did:   I first downloaded the exe. Ran it. Then I found that it extracts the msi to the following folder: %USERPROFILE%\AppData\LocalLow\Sun\Java\jre1.8.0_20. Then I
  • I was a happy user of WinCDEmu for a very long time, but lately it made me very itchy - way too many issues, so I went back to Virtual Clonedrive, which I ''left'' because it didn't have .nrg cd-audio
  • Thanx it works good
Hi @ricktendo64,
Can you make a repack installer "Dropbox v1.4.5 Final" with this properties pls?
- Run on Windows startup Removed
- No ask user account login info in setup process
- Remove if it contains old VC runtimes etc.
Thank you. :icon_cool:
Edited by oguz
Extra info for my wish (''request'') regarding QuickTime 7.7.2.80.56 - it needs five changes to make it less annoying for those who aren't very attentive to the setup process.
More precisely, three changes to the install process (unchecked the desktop shortcuts, unchecked the go pro pop-up screen after the install process and unchecked the box for search updates for apple software by default), and two regarding the installed software (the quicktime task - QTTask.exe - removed from startup, and the ''check for updates automatically'' unchecked from the update tab in the quicktime preferences - it's still checked although I manifested the same wish during setup... typically Apple).
Hopefully these are all the changes needed to stop Apple from connecting to its servers without my knowledge. Of course an updated QT Lite would be fantastic, since I don't think anyone reading this post (advanced users) uses the quicktime player, they just need the quicktime browser extensions, but as I've said it seems QT Lite won't be updated no more...
  • 4 weeks later...
Hi @Rick,
Can you [Repak] Windows Media Player 11 + KB970159 (full update) for Turkish language?
Thank you :)
Edited by oguz
Done, let me know how if it works oguz
BTW its not a "full update" you still have to integrate the other wmp11 hotfixes
Let me know if it worked
Thank you very much for your quick reply and repack. I haven't tested yet. I guess it will work without problems. I'll let you know after testing and integrating full updates.
How to repack it? it is safe to delete DNF1.1? Do i need 7zip SFX Stub and the config for stub? I also already forgot the command for repacking copy /b DNF.7z + stub.sfx + config.?
If it need the stub can you please provide the stub and the configuration file thanks!
Edited by gendouhydeist
NDP40-KB2600211-x86-x64.exe
a new net 4.0.3 update pack... would be very nice to include it in 4.0 or make a separate pack. thx, good work :)
Rick, have you thought of doing a dual (x86/x64) Microsoft Security Essentials repack?
I use the following switches: mseinstall-amd64fre-en-us.exe /s /q /o /runwgacheck (same for 32-bit version)
But I get a "Click 'OK' to continue" error about revoked certificates (on Win7). (ignore, it was Java that caused the error).
I'd like to make it fully unattended and thought that a combined repack with the updated definitions would be ideal.
Download page: http://windows.micro...rity-essentials
Edited by Mr_Smartepants
Yea, I was totally trying to do a mst that would allow me to install directly via msi and also copy the updated definitions automatically but I failed (you can see my attempt here)
As for a "repack" that is silent you could not use the SFXCAB.exe because the options are very limited (you can only point to the exe you cant add switches,) it would have to be done with 7zip sfx but I think I could also add a switch that would automatically install the program depending on arch and could also install the updated definitions if you put it in the same dir as the 7zip installer
I'm thinking something like this
;!@Install@!UTF-8!
GUIMode="2"
RunProgram="%%P\\setup /s /runwgacheck /o"
;Use /ai to install definition updates (in same dir as installer) automatically
AutoInstall="%%P\\setup /s /runwgacheck /o"
AutoInstall="x86:\"%%S\\mpam-fe\" /q"
AutoInstall="x64:\"%%S\\mpam-fe%%P\" /q"
;!@InstallEnd@!
Edit: Here it is in case anybody wants to test it
http://adf.ly/1713566/msseces
MD5: aef9b6c1953657a8f4690ad49632ee2a
Download the definition updates (to be used with /ai) from KB971606
I use the following batch file to take care of it. Works fine for me.
:Security-Essentials
ECHO>>"%LOGFILE%" ......................
ECHO Installing Microsoft Security Essentials & ECHO>>"%LOGFILE%" 2>>&1 Installing Microsoft Security Essentials
IF "%ARCH%"=="64" (
%CDROM%\updates\MSSE\mseinstall-amd64fre-en-us.exe /s /q /o /runwgacheck >>"%LOGFILE%" 2>>&1
%CDROM%\updates\MSSE\mpam-fex64.exe -Q >>"%LOGFILE%" 2>>&1
) ELSE (
%CDROM%\updates\MSSE\mseinstall-en-us-x86.exe /s /q /o /runwgacheck >>"%LOGFILE%" 2>>&1
%CDROM%\updates\MSSE\mpam-fe.exe -Q >>"%LOGFILE%" 2>>&1
:Defender-Definitions
ECHO Installing Windows Defender Definition updates & ECHO>>"%LOGFILE%" 2>>&1 Installing Windows Defender Definition updates
IF "%ARCH%"=="64" (
%CDROM%\updates\WinDefUpdate\mpas-fex64.exe -Q >>"%LOGFILE%" 2>>&1
) ELSE (
%CDROM%\updates\WinDefUpdate\mpas-fe.exe -Q >>"%LOGFILE%" 2>>&1
OK, I tried it in VM on both 32 & 64 bit Win7 and your repack works fine. When using /ai there is zero feedback on install process (truly silent). Is there a different switch that provides a progress bar and updated definitions?
What kinda progress bar would you like?
Are you talking about a wizard type thing like .net4?
For the time being you can override/enable the "extraction" progress bar by adding /gmX
Display Mode Unpack Where X:
  • 0 - Normal Mode - Native Mode 7-Zip Archiver, I.E. With Buttons "Cancel" And "Close" (Which In The UpperRight Corner)
  • 1 - Display The Process Of Unpacking But Hide The "Cancel", Button To Block The Close "Button" (Which Is In The Upper Right Corner Of The Window) And Press Esc Key On Your Keyboard
  • 2 - Do Not Display The Extraction Dialog Completely (ie "quiet" Mode)
MsSecEs.exe /ai /gm0
For setup install progress IDK what the cmdline is for that, maybe change /q to /passive in my config.txt
