Posted April 8, 200718 yr The free program Amnesty Generator lets you take a gadget that you find on the Web, and (as if by magic) transform it into a gadget that can live on the Windows Vista sidebar. You don't have to know a lick of code to perform this trick either; all you have to do is click a few buttons, and cut and paste.Install Amnesty Generator. Then, when you come across a Web gadget you'd like to turn into a Vista gadget, click a few buttons to display the gadget's underlying HTML code. Copy and paste that code into Amnesty Generator, change a few settings (such as the gadget's name or size) if you wish, and tell Amnesty Generator to turn it into a Windows Vista gadget. The gadget will appear in the Windows Vista Gadget Gallery; from there you can move it to the Sidebar, and it will work just like any other Windows Vista gadget.One caveat: This tool can't convert and run every gadget you find on the Web, and there's no way to know ahead of time which will work and which won't, so you'll have to find out by trial and error.License Type: FreePrice: FreeDate Added: Apr 2007Operating Systems: Windows VistaRequirements: Windows VistaFile Size: 4610KBAuthor: Mesa Dynamics Homepage: Mesa Dynamics Download Edited April 8, 200718 yr by cro-man
