Hi @Lego,
There is a serious problem about .msi files in WinKit v17 :g:
The applications released in "Installer Repack" new topic by @Ricktendo64 give "Shutdown.exe" Error while they are installed, and this causes restart before the system reaches to the desktop.
Thank you.
Edited by oguz
Its not win toolkit problem then, I suspect its Microsoft Camera Codec Pack the latest version asks to reboot...to avoid this use
<installer_name>.msi /qn REBOOT=ReallySuppress
or
<installer_name>.msi /qn /norestart
http://msdn.microsof...4(v=vs.85).aspx
Edit: I updated the installers to suppress reboot
Thanks @Rick,
I'll try 'norestart' command. However, I don't think this is the only problem. Although Skype seems to be installed properly, i saw that Skype was not installed in the system.
Ps 1: Is "norestart" command only for camera codec pack? Or is it for other msi packages too? If yes, for which ones?
Ps 2: I saw that camera codec pack was installed without a problem in program add remove before.
There are some problems but I could not solve them. :shifty:
Edited by oguz
I cannot speak about v17 because I had constant errors but v10 added my codec pack with no errors using /qb /norestart
EDIT: Meant v17 not v16
Edited by compstuff
@Rick and @compstuff
Repack .msi files (skype, camera codec pack, shockwave player, visual c+ runtimes) are installed Without An Error with WinKit v12.
It is certain that the problem is in WinKit v17 :shifty:
Edited by oguz
@Lego,
Thanks for v18
I can't see any fixes of msi files in changelog. Do you plan to fix msi files problems?
Fixed.
EDIT 1:Also if the user (you) don't specify a switch/syntax for msi files the RunOnce will automatically add '/passive /norestart'
EDIT 2: If there is a /forcerestart or /norestart in the specified switch it will change them to '/norestart' and if restart option is not specified then it will auto add /norestart :)
Edited by Legolash2o
