Posted May 23, 201212 yr Hi.I want run WPI in Registering componenets : Edited May 23, 201212 yr by Behdadsoft
May 24, 201212 yr Hello!WPI = Windows Post-Install WizardVery useful to install silently all your programs after Windows installation.Many thanks to Kels for his very nice software. :thumbsup_anim:Cheers
May 25, 201212 yr Ah wait your the guy from msfn that can't follow Eula's or simple instructions.. (Also bolstered by the fact you can't even post in the WPI sub-forum here)You will find NO help here..Watch your step here, I will ban you without a second thought if you pull the same crap here as you have done at MSFN!
