Posted May 28, 201212 yr Where can I get one or what files to I put under [obsolete_files] in my entries.ini file.
May 28, 201212 yr For starters you can add ie.inf along with the copyfiles listed in it (but there may be a couple other ie files)
May 28, 201212 yr Author where can i find ie.inf, I can't find it.EDIT: I found it but It's not the original. It was modified in 2008 & by IE8. It can't be the IE6. Edited May 28, 201212 yr by ShyGuy
