[Solved] Help - Cannot integrate Language Pack (SP1/x64)
Hello all,
I'm trying to edit the Windows 7 Professional SP1 x64 and I downloaded the English version via the Win Toolkit.
I also used Win Toolkit to download the French LP SP1 x64 version.
After I converted the EXE to CAB using the feature found in Win Toolkit.
But every single time I try to integrate the LP via the AIO Integrator, it shows as red and the LP is not included.
Where can I find the log to check this? Or is some bug? Or?
Thank you all for the support.
Cheers,
/Arky
Hello! Thanks for the answer.
I wasn't sure of that because just recently I bought my wife one of those Ultrabooks and it came with Home Premium pre-installed.
But during the first boot, it asked to what language Windows should use, and there were all the major european ones. After, since it's Home Premium, you cannot change the language anymore, but the option was there, I'm not crazy!!! :w00t: :w00t: :w00t: :w00t:
The first boot screen was the one that you are asked to choose language, keyboard and timezone.
Oh well, I figured it would be possible then.
Thanks!
Posted (edited)
Ok, just tried with an Ultimate version. Same error :(
PS: Just saw your post. Will check it out. Thanks!
Edited by Arkymedes
Posted (edited)
You can remove the Dism.log file and try again to integrate language pack.
A new Dism.log file will be created.
Remember: you need to use every time a new install.wim file "fresh copy" if you have errors!
Edited by myselfidem
