Posted June 1, 201212 yr Hi all,the actual release of Win Toolkit put the modified lang.ini in boot.wim\1\sources\ ,not in the correct path: boot.wim\2\sources\ .without modified lang.ini in 2/sources , the "chosing language" menu at the start of installation not appear.bye & tnx in advance.theSLug Edited August 4, 201311 yr by theSLug
June 1, 201212 yr Just tested this and it seems to work fine, however if Win Toolkit does not detect image #2 it will mount image #1 instead which may have happened to you.I'll make a few changes to see if that helps
June 4, 201212 yr Author Tnx for the reply Lego, i use the classic boot.wim from sp1 or sp1 media refresh disk. SHA1:B4EE5DA87F38DCF48CDD70EB822908AA26DB9484 .If I can do something to help, tell me.this is my mount log:[3732] [ INFO ] Mounting new image.Wim: [***\DVD\SOURCES\boot.wim]Image Index: [1]Mount Path: [*7toolkit_temp\WinToolkit\Boot][3732] [ INFO ] Wimserv process started for guid aefefa64-879b-4213-abe3-77d288e11d7c. Id is 3616[3616] [ INFO ] ImageUnmarshallHandle: Reconstituting wim at ***\DVD\SOURCES\boot.wim.[3616] [ INFO ] Mounted image at *7toolkit_temp\WinToolkit\Boot.[5136] [ INFO ] ImageUnmarshallHandle: Reconstituting wim at ***\DVD\SOURCES\boot.wim.[3616] [ INFO ] Received unmount request for image with guid aefefa64-879b-4213-abe3-77d288e11d7c.[3616] [ INFO ] Unmount for image at *7toolkit_temp\WinToolkit\Boot complete.tnx again.theSLug
June 4, 201212 yr I need to things if you don't mind.1) You're last_session.ini for when you tried to integrate the LP2) Open your boot.wim with 7zip and attach the [1].xml3) Have you tried v21 or v22?Thanks.
June 4, 201212 yr Author latest try with v19[OT]why boot.wim include 2 image?? 1 for installation and 1 for system recovery??? [/OT]tnx again Lego theSLug1.xml2012-05-31_10-17-42_2012-05-31_10-17-42.ini Edited June 4, 201212 yr by theSLug
June 4, 201212 yr I made some changes with v21, so please test that first Thanks for looking at the files, i'll have a look now but please try the latest version.
June 4, 201212 yr Author Another question.the integration of LP always work, but, why the red line, is normal?
June 4, 201212 yr You can only integrate Language Packs into Ultimate and Enterprise editions. If it works then don't worry about it.So did it mount the 2nd boot image instead of the 1st?
June 4, 201212 yr Just an update: I've fixed the bug which make language packs appear red instead of green
June 4, 201212 yr Author Hei Lego, now lang.ini is not present in boot.wim\1\sources\ and the correct modified vesrsion is in boot.wim\2\sources\ :[Available UI Languages]de-DE = 2en-US = 3es-ES = 2fr-FR = 2it-IT = 2ru-RU = 2[Fallback Languages]en-US = en-usall perfect :D Edited June 4, 201212 yr by theSLug
June 4, 201212 yr Author Just an update: I've fixed the bug which make language packs appear red instead of green WOW.tnx again man for your great work!!!!! probably theonlyone"Dino" is following you
June 4, 201212 yr Glad it's now working. If you're wondering what i changed i will explain below.BEFORE--------------------------Win Toolkit would check the wim information to determine if there was image #2 ([1].xml) but sometimes it could not get the information or at least get it correctly, so then it would mount #1 even if #2 existed.AFTER-------------------------It no longer tries to get the information before hand and just attempts to mount #2 regardless if that information is there or not, only if that fails it will try and mount #1.
November 12, 201212 yr Author hi great Lego,the problem is reproposed.i make a new build today (WT1.4.0.77), with:#UpdatesX:\langpacks\x64\lp_ru-ru.cabX:\langpacks\x64\lp_de-de.cabX:\langpacks\x64\lp_es-es.cabX:\langpacks\x64\lp_fr-fr.cabX:\langpacks\x64\lp_it-it.cabX:\AddOn\x64\IE9-win7_x64.msuthe resulted lang.ini is:[Available UI Languages]en-US = 3[Fallback Languages]en-US = en-ussame in sources and in boot.ini\2\sources\LP is integreted correctly, i changed the lang without WU.for serve you,theSLugEDIT: testing on WT 1.5.0.1EDIT2: same on 1.5.0.1EDIT3: the 1.5.0.1 has a different behavior, what is install pending? LP files copied in install.wim but not in boot.wim no lang.ini modified.MOUNT LOGS:Microsoft Windows Setup (x64)_64605.log[2352] [ INFO ] Mounting new image.Wim: [E:\7usab\DVD\SOURCES\boot.wim]Image Index: [2]Mount Path: [E:\7toolkit_temp\WinToolkit_TEMP\Boot][2352] [ INFO ] Wimserv process started for guid 3133baaf-c443-4a76-8809-0bf2f142be99. Id is 5536[5536] [ INFO ] ImageUnmarshallHandle: Reconstituting wim at E:\7usab\DVD\SOURCES\boot.wim.[5536] [ INFO ] Mounted image at E:\7toolkit_temp\WinToolkit_TEMP\Boot.[5536] [ INFO ] Received unmount request for image with guid 3133baaf-c443-4a76-8809-0bf2f142be99.[5536] [ INFO ] Unmount for image at E:\7toolkit_temp\WinToolkit_TEMP\Boot complete.Microsoft Windows Setup (x64)_78334.log[5704] [ INFO ] ImageUnmarshallHandle: Reconstituting wim at E:\7usab\DVD\SOURCES\boot.wim. Edited November 13, 201212 yr by theSLug
November 15, 201212 yr Ok someone says it's not working and then someone else says it's working. Which one is it? As usually, please try with the latest test build.
November 19, 201212 yr Author @Legolash2oi tested the last builds (test38 for 1.5)@rulmanmore input please.
November 19, 201212 yr Author I use; WinToolkit150-1_Test38it works perfectlywell donesame build... wtf... i retest it... but the "install pending" at the end of build is a bit confusing
November 19, 201212 yr The install pending simply means that the installs will happen as the OS is actually installed.Cheers and Regards
November 19, 201212 yr Author The install pending simply means that the installs will happen as the OS is actually installed.Cheers and Regardstnx man but.. in which part of my configuration file is this... :shy:EDIT: anyhow, test38 built give me same resulttest64.ini Edited November 19, 201212 yr by theSLug
