Hi @Lego,
I have questions about the process order when win toolkit is working. Does win tool kit follow this process sequence as below?
1- to mount the image file first
2- if a multi image file, to get the desired folder by "removing config.exe" and delete others
3- integrate windows updates
4- upload silent and msi installers (if there is any)
5- delete windows components (language packs, sample music, etc.)
6- apply windows tweaks
7- integrate the drivers
8- create a new image
9- etc.
As in the example above, does wintoolkit do all these processes In a correct and logical order automatically? Or what?
Edited by oguz
