Posted June 7, 201212 yr I created my bootable Win 7 USB using Win Toolkit. Win 7 was installed correctly along with all the addons, though some of the tweaking didn't appear after the installation - like Move to, Copy to options in the context explorer.But none of the silent installers were installed. I tried each of the installer myself with various switches using the CMD prompt and everything was working fine but when I created a image with Win Toolkit along with the addons and silent installer nothing got installed after windows installation. Even the silent installers provided in this forum for Flash Player, Java Runtime environment didn't install.Also the display of the Win Toolkit in my system is not complete. Few of the options are hidden.I am attaching the screenshots and few configuration files for debugging.The silent installers I added were:1. Reapers.Java.Runtime.AIO.7.0.40.20.x642. Reapers.Adobe.Flash.Player.AIO.11.2.202.233.x643. Reapers_Adobe_Shockwave_Player_11.6.4.6344. 7z465-x645. Driver Magician 6. EPM7. iCareDRS8. WinRARetc etc...Please help me out in creating this bootable USB pendrive.If you need any further details then let me know.Attaching the screenshot of the contents of USB also.Configuration Files.zipUSB Contents.zip Edited June 7, 201212 yr by vipul_tilak
June 7, 201212 yr I am not saying this is your problem but I would recommend eliminating any spaces you use in your folder structures. I always use an underscore instead of spaces.
June 8, 201212 yr I am not saying this is your problem but I would recommend eliminating any spaces you use in your folder structures. I always use an underscore instead of spaces.Good job you noticed, Win Toolkit will ALWAYS replaces spaces with underscores, did you manually copy and paste the files/folders?EDIT: Use WIM Registry Editor and browse to HKLM\\WIM_Software\\Microsoft\\Windows\\CurrentVersion\\RunOnce and take a screenshot please.
June 9, 201212 yr Author I made the USB bootable using the option "USB Boot Prep" and then copy pasted all the contents of the DVD, which was created by "All-In-One Integrator".Attaching the screenshot of the registry as required.Also can you please elaborate on the spaces you are talking about. Are there any spaces in the name of the EXE??I dont see any space in my folder structure and not even in the Apps folder created in the DVD directory of Win 7.Also just wanted to let you know that the display problem is now fixed with latest version 140-25 and I can see all the option in one screen now. Edited June 9, 201212 yr by vipul_tilak
June 9, 201212 yr You uploaded the wrong picture. Can you please use Win Toolkit > Main > Advanced > WIM Registry Editor, select the image you had your silent installs on.Load 'Software' key and take a screen shot of 'HKLM\\WIM_Software\Microsoft\Windows\CurrentVersion\RunOnce'
June 9, 201212 yr Author Oops couldn't understand the first time!!Here you go!!One more if this can also help you!!! Edited June 9, 201212 yr by vipul_tilak
June 9, 201212 yr I hope Lego has better eyesight than I do because I can't read either one of those pics. Any chance for a larger version?Cheers and Regards
June 9, 201212 yr You're probably better off doing that again but 'export' the RunOnce and WinToolkit registry keys within WIM_Software.
June 11, 201212 yr Author You're probably better off doing that again but 'export' the RunOnce and WinToolkit registry keys within WIM_Software.Didn't understand "'export' the RunOnce and WinToolkit registry keys within WIM_Software"Can you please help me step by step instructions as I am a newbie in this?I will create a boot dvd and then load it onto a bootable USB. What extra do I need to do here??
June 11, 201212 yr Author Tried everything with v.0.25 but no luckFew config files are attached here.The apps folder is created in the DVD and the system boots up from USB and the windows is loaded.After windows is loaded it asks for the Username, Password, time-zone, and wifi settings.After that it restarts and Preparing you Desktop message comes and I guess it installs the addons that were added but it DOES NOT install any silent installers.Please let me know where am I going wrong!!!All this is done on Win 7 Ultimate x64 version.Registry.txtSettings.txt2012-06-09_17-45-03_9_June_2012.iniWindows 7 ULTIMATE (x64) - Copy.txt Edited June 11, 201212 yr by vipul_tilak
June 13, 201212 yr Everything seems to look fine :S Mount your image, is there a WinToolkitRunOnce.exe or something like that. Also after Windows is installed, there should be a log file in System32 (WinToolkit_RunOnceLog.txt), can you please attach it
June 14, 201212 yr Author Everything seems to look fine :S Mount your image, is there a WinToolkitRunOnce.exe or something like that. Also after Windows is installed, there should be a log file in System32 (WinToolkit_RunOnceLog.txt), can you please attach it Thanks a lot for pointing out this log file, The reasons why silent installers were not installing was - I boot from USB and after the first restart I remove the USB to boot it from hard drive. So what happens is it was not able to find the USB drive and the Apps directory.I connected the USB drive and run the WinToolKit Run Once Installer and it installed everything perfectly.I will give it a try once again with a fresh install and post the final results.PFB the logs:4.6.3.0 (Looking for CommandLineArgs...)CommandLineArg: C:\Windows\System32\WinToolkitRunOnce.exe (Looking for CommandLineArgs...)Found Drive: C:\ (Looking for Installation Files...)Found Drive: D:\ (Looking for Installation Files...)Found Drive: E:\ (Looking for Installation Files...)Found Drive: F:\ (Looking for Installation Files...)Found Drive: G:\ (Looking for Installation Files...)Found Drive: H:\ (Looking for Installation Files...)Found Drive: I:\ (Looking for Installation Files...)Found Drive: C:\ (Looking for alternatives...)Found Drive: D:\ (Looking for alternatives...)Found Drive: E:\ (Looking for alternatives...)Found Drive: F:\ (Looking for alternatives...)Found Drive: G:\ (Looking for alternatives...)Found Drive: H:\ (Looking for alternatives...)Found Drive: I:\ (Looking for alternatives...)IDrive: (Looking for alternatives...)No IDrive Found: (Aborting: No installation files found...)Thanks a lot Legolash!!!!Will post the results soon!!!
June 28, 201212 yr Glad you found the issue, i may add a warning to not remove USB/DVD until the user has seen the desktop.
July 17, 201212 yr Author Sorry for the long delay!!!Everything is working fine along with the updates !!!Thanks
July 17, 201212 yr Since I have wondered in the past about other versions functioning or not for integration I can report that v33 worked for all my updates and my SFX/silent installers... I didn't get to try v34 yet.
