June 17, 201212 yr STEP 1. Right-click on Windows 8 Desktop and select "Personalize" option. It'll open Personalization window.Make sure default Aero theme is applied. If it is not, apply Aero theme.Now click on "Window Color" link given at the bottom of the window. Keep the window opened.STEP 2. Now again right-click on Desktop and select "Personalize" option. It'll open another Personalization window. Now click on "Windows Basic" theme to apply Aero Lite theme.It'll apply Aero Lite theme and obviously you'll not get Aero glass.STEP 3. Now the tricky part comes. Go to previously opened Personalization window which we opened in Step 1.Uncheck "Enable transparency" option and then re-check it. Click on "Save changes" button and get ready to enjoy Aero glass in "Aero Lite" (Windows Basic) theme.Let me know if this helps..Source: AskVG
June 17, 201212 yr Any way by which we can get it? I mean some tools or something?You are going to have to use windowblinds or something similar, this is what its going to look like (like XP IMO)
