June 22, 201212 yr Thanks for the info, i experience lots of hangs but my graphics card is AMD EDIT: There was an update for my graphics card, updated it and hopefully it will be much better. I'm betting the problem is with the default driver installed.
June 22, 201212 yr try ati catalyst 9.00-12061a its fully windows 8 comatible.windows 8 runs slick on these.you can find the on guru3d.com in forums section.EDIT: http://downloads.gur...6.html#download Edited June 28, 201212 yr by Legolash2o Added link to driver
June 28, 201212 yr Some other possible solutions is to install Hyper-V via 'Turn Windows features on or off' and also go to network drivers properties > Advanced > Disable 'Green Energy'
