June 18, 201212 yr Try it and see if you like it. Use it - not yet, most comments indicate it's not ready.A dual/multi-boot setup would be best - for comparison.
June 19, 201212 yr A dual/multi-boot setup would be best - for comparison.One better would be to use a virtual machine. As a developer, you probably should have several anyway just so you do not mess up your production machine. That is likely what I would do if I had any interest in Windows 8. Right now, not so much.
June 22, 201212 yr I've got release preview installed with the Visual Studio 2012 RC too, it's good apart from it hangs a lot for me the Win 8 Beta is much better.
July 21, 201212 yr Why don't you install it as a VHD as dual boot? It is much cleaner and you can get rid of it later much easier.
