After installing Windows does not work WinToolkitRunOnce. Installation CD will not eject from the device. Software version 14.0.27. In addition, if you add a CAB archive updates. they are not integrated and are marked in red
Title: 29 error(s) have occurred
ErrType: Error
Description: Win Toolkit has recorded errors which occurred during integration and have been stored via '>> Details'.
Exception:
Exception:
Error integrating silent installer:
Exception:
Object reference not set to an instance of an object.
Win Toolkit v1.4.0.27
Win Toolkit Directory: d:\perevod\Lite
System Directory: C:\Windows\system32
DISM Location: C:\Windows\System32\Dism.exe
Microsoft Windows NT 6.1.7601 Service Pack 1 (ru-RU)
Windows 7 Ultimate (32-bit,4)
7601.17803.x86fre.win7sp1_gdr.120330-1504
fAddons=
fDrivers=
fGadgets=
fSilents=E:\TEST\PROGRAMM
fThemes=E:\TEST\PROGRAMM\Theme
fTweaks=
fUpdates=E:\TEST\UPDATE32\1
fWallpapers=
sAICommands=True
sAVScan=False
sAIOSave=True
sPreventSleep=True
sCheckForUpdates=False
sDLogging=True
sFreeRAM=True
sLastDir=C:\Users\LOGINVOVCHYK\Desktop
sLastWIM=C:\7Work\DVD\SOURCES\install.wim
smCheck=False
sAIOPM=False
sMountTemp=C:\W7T\Mount
sQuickMerge=True
smVerify=False
sSolDownload=D:\perevod\Lite\SoLoR\
sTMAero=True
sTransparency=100
sTransparencyAll=False
sWinToolkitDISM=Обычный
sWinToolkitExt=Обычный
sWinToolkitPRI=Обычный
sWinToolkitTemp=C:\WinToolkit
sUploadLogs=True
sLastISO_Folder=C:\7Work\DVD
sLastISO_ISO=C:\7Work\ISO\2.iso
sMountLog=True
sWelcomeTab=False
sDownloadTab=True
sToolsTab=True
sRegistryLog=False
Form: All-In-One Integrator (Windows 7 ULTIMATE)(frmAllInOne)
Description: Unable to prepare listed items, loaded so far:
#Silent Installs
::Н/Д (не требуется);NO;4.07 MБ;E:\TEST\UPDATE32\1\Windows6.1-KB2533552-x86.msu;
Status: Preparing List...
Exception: Object reference not set to an instance of an object.
#Silent Installs
#Silent Installs
Exception: В экземпляре объекта не задана ссылка на объект.
Edited by loginvovchyk
About IE9 and language packs, I see there is two language packs (example for French):
One include inside IE9-Windows7-x86-fra.exe (full version). Extracted language file is : ielangpack-FRA. CAB
Another language pack .cab file inside: IE9-Windows6.1-LanguagePack-x86-fra.msu => Windows6.1-KB982861-x86.cab
It seems - to avoid errors - it's better to use the extracted language pack "Windows6.1-KB982861-x86.cab" using IE9-win7.msu.
http://www.microsoft...ls.aspx?id=1944
Tested here:
http://www.msfn.org/board/topic/150416-msu-version-of-internet-explorer-9/page__view__findpost__p__959478
Always install first IE9 and after language pack, and after IE9 updates and all other updates!
Errors occurs if some updates are already integrated first!
Regards
Edited by myselfidem
To integrate IE9, we have several possibilities:
1 - We can also download the full IE9-Windows7-x86-fra.exe (example french version) and extract the files to integrate inside the install.wim mounted image with the two .cab files:
IE9-Win7.CAB and ielangpack-FRA.CAB
2 - IE9-win7.msu + Windows6.1-KB982861-x86.cab (extracted from IE9-Windows6.1-LanguagePack-x86-fra.msu)
And not using: ielangpack-FRA.CAB with IE9-win7.msu. To avoid errors!
Tested the two methods successfully!
Cheers
In version 14.29 IE language pack can not be integrated, although the order of integration is correct. If you are interested I can send you a script file for the integration of updates. Perhaps in this file you will find the cause.
This file is the script integrates all right!
After installing Windows does not work WinToolkitRunOnce. Software version 14.0.30!!!!
I have to draw your attention to this problem a third time but you do not fix it why?
In versions 1.3 x WinToolkitRunOnce worked perfectly, starting with version 1.4 has stopped working!
_____________________________________
Report the file WinKit_RunOnceLog.txt
4.5.1.0 (Looking for CommandLineArgs...)
CommandLineArg: C:\Windows\System32\WinToolkitRunOnce.exe (Looking for CommandLineArgs...)
Found Drive: A:\ (Looking for Installation Files...)
Found Drive: C:\ (Looking for Installation Files...)
Found Drive: D:\ (Looking for Installation Files...)
IDrive: D:\ (Looking for Installation Files...)
Enumerating Installation [sOFTWARE\WinKit]... (Enumerating Installation [sOFTWARE\WinKit]...)
Enumerating Installation [sOFTWARE\W7T]... (Enumerating Installation [sOFTWARE\W7T]...)
No items to install (Aborting: No programs to install...)
Screenshots
I tried just now the 1.4.0.31 and it works: all progs have been installed, what I have put in AIO as silent-install and all updates have been integrated.
BTW: german OS and (of course) german updates.
@Legolash2o:
May be the problem of loginvovchyk are russian characters?
Regards, Thiersee
In version 1.3 it worked well even with Russian characters! Starting with version 1.4 and above WinToolkitRunOnce does not work. At first I thought it was because The program of the Russian translation, but in the original (English version also does not work WinToolkitRunOnce)
I do not understand why WinToolkit version 1.4.32 generates a WinToolkitRunOnce.exe version 4.5.1.0, instead of 4.6.3.0.
Does your program around a copy of WinToolkitRunOnce.exe?
I seem to have found the reason why is not the correct file is generated WinToolkitRunOnce.exe.
After the localization of your program, a program for the localization does not update the old data. To fix this error, I want to send a report to the developer of the program to correct this error. But for this I need your help to find out which module generates a WinToolkitRunOnce.exe?
