Posted July 1, 201213 yr Once again I'm stuck on an inf problem. Does anyone know of a way to append to the %PATH% using an INF installer?I know that the path is stored in the registry at: HKLM,"SYSTEM\CurrentControlSet\Control\Session Manager\Environment","Path"And I know it would be easy to replace the path. The question is can I append to the existing path in the registry?And, then, to really complicate matters... Would there be a way to uninstall the appended path portion ONLY on an uninstall? I'm probably asking for too much, now. :albert: Edited July 1, 201213 yr by Uncle_Gadget
July 1, 201213 yr Ive struggled with this too, I can get append (0x10008) to add but never could figure out the uninstall
July 1, 201213 yr Author Ive struggled with this too, I can get append (0x10008) to add but never could figure out the uninstallThanks. Even this helps. I'll probably write a simple AutoIt executable and execute it during RunPostSetupCommands=
July 1, 201213 yr Author I was doing a bit more research and found the Registry Data Types below. Is there a difference between NOCLOBBER and APPEND?; REG_MULTI_SZ_APPEND = 0x0001000A; REG_MULTI_SZ_NOCLOBBER = 0x00010002I know it doesn't help me with a REG_EXPAND_SZ, but wouldn't the line below work as an uninstall data type for REG_MULTI_SZ?; REG_MULTI_SZ_DELVAL = 0x00010006
July 6, 201212 yr Author If anyone's interested, I wrote a fairly sophisticated AutoIt script to add/remove to/from %PATH% using the registry.If you run it silently, it will generate an ERRORLEVEL if it encounters any errors while executing. Feel free to use or modify as needed.#region ;**** Directives created by AutoIt3Wrapper_GUI ****#AutoIt3Wrapper_Outfile=C:\Users\Public\Desktop\Uninstall.exe#AutoIt3Wrapper_Compression=4#AutoIt3Wrapper_UseX64=n#AutoIt3Wrapper_Res_Description=Append or Remove elements from %PATH%#AutoIt3Wrapper_Res_Fileversion=1.0.0.16#AutoIt3Wrapper_Res_Fileversion_AutoIncrement=p#AutoIt3Wrapper_Res_Language=1033#AutoIt3Wrapper_Res_requestedExecutionLevel=requireAdministrator#AutoIt3Wrapper_Res_Field=ProductName|PATH Appender-Remover#AutoIt3Wrapper_Res_Field=ProductVersion|1.0#AutoIt3Wrapper_AU3Check_Stop_OnWarning=y#AutoIt3Wrapper_Run_Tidy=y#endregion ;**** Directives created by AutoIt3Wrapper_GUI ****#cs ----------------------------------------------------------------------------AutoIt Version: 3.3.8.1Author: Uncle GadgetScript Function:This script will appends or remove elements from the %PATH% Environment#ce ----------------------------------------------------------------------------Local $Silent, $NewRegPathGlobal $CommandError = "Uninstall.exe <a/r/as/rs> <path to append/remove>" & @LF & @LF & _ " a = Append to existing %PATH%" & @LF & _ " r = Remove from existing %PATH%" & @LF & @LF & _ " as = Append (silently) to existing %PATH%" & @LF & _ " rs = Remove (silently) from existing %PATH%"If $CmdLine[0] <> 2 Then; not enough Command Line parameters were entered MsgBox(262160, "Command Line Error (1)", "Uninstall.exe expects parameters to be as follows:" & @LF & @LF & _ $CommandError) Exit 1EndIfGlobal $Path = StringStripWS($CmdLine[2], 3) ; Strip all White Space from Begin and End of Command Line (2)Global $Command = StringLower(StringStripWS($CmdLine[1], 3))Local $RegPath = RegRead("HKLM\SYSTEM\CurrentControlSet\Control\Session Manager\Environment", "Path")Switch $Command Case "as" ; (a)ppend / (s)ilent $Silent = 1 ; Turns on the Silent (No Output) Flag to eliminate any user output ContinueCase ; Continue on to Append below Case "a" ; (a)ppend Opt("ExpandEnvStrings", 1) ; Turns ON Expanded Environment Strings If Not FileExists($Path) Then ; the requested Path to Append/Remove does not exist - ERROR If Not $Silent Then ; we'll let User know about error if 's'ilent was NOT specified MsgBox(262160, "Path Does Not Exist (2)", "The Path to append (below) does not currently exist." & @LF & @LF & _ $Path & @LF & @LF & _ "Verify that Path exists prior to execution.") EndIf Exit 1 EndIf $LowerPath = StringLower($Path) $LowerRegPath = StringLower($RegPath) $ExpPathLen = StringLen(";" & $Path) Opt("ExpandEnvStrings", 0) ; Turns OFF Expanded Environment Strings If $LowerPath & ";" = StringLeft($LowerRegPath, $ExpPathLen) Or StringInStr($LowerRegPath, ";" & $LowerPath & ";") Or ";" & $LowerPath = StringRight($LowerRegPath, $ExpPathLen) Then ; the path to remove is currently somewhere in %PATH% If Not $Silent Then ; we'll let User know that Path to Append currently exists in %PATH% MsgBox(262208, "Path Currently Exists (3)", "The Path to append (below) is currently specified in %PATH%." & @LF & @LF & _ $Path & @LF & @LF & _ "No changes will be made to the %PATH%.") EndIf Exit 0 ; Although no changes were necessary we'll exit with no error since our mission WAS accomplished EndIf $AppendWrite = RegWrite("HKLM\SYSTEM\CurrentControlSet\Control\Session Manager\Environment", "Path", "REG_EXPAND_SZ", $RegPath & ";" & $Path) If Not $AppendWrite Then ; some sort of error occurred while writing If Not $Silent Then ; we'll let User know about error if 's'ilent was NOT specified MsgBox(262160, "Registry Write Error (4)", "Unable to write appended %PATH% to the registry." & @LF & @LF & _ "Error Code Returned was: " & @error & @LF & @LF & _ "Review command line options before trying again.") EndIf Exit 1 EndIf If Not $Silent Then ; we'll let the User know that all changes have been made as requested. MsgBox(262208, "Path Successfully Appended", "The path (below) was successfully appended to %PATH%." & @LF & @LF & _ $Path) EndIf EnvUpdate() Exit 0 Case "rs" ; ®emove / (s)ilent $Silent = 1 ; Turns on the Silent (No Output) Flag to eliminate any user output ContinueCase ; Continue on to Remove below Case "r" ; ®emove $PathLen = StringLen(";" & $Path) If $Path & ";" = StringLeft($RegPath, $PathLen) Then ; the path to remove is at the BEGINNING of %PATH% $NewRegPath = StringTrimLeft($RegPath, $PathLen) ; and we'll create the new %PATH% String by Trimming of the beginning of %PATH% ElseIf StringInStr($RegPath, ";" & $Path & ";") Then ; the path to remove is in the MIDDLE of %PATH% $NewRegPath = StringReplace($RegPath, ";" & $Path & ";", ";") ; and we'll create the new %PATH% String ElseIf ";" & $Path = StringRight($RegPath, $PathLen) Then ; the path to remove is at END of %PATH% $NewRegPath = StringTrimRight($RegPath, $PathLen) ; and we'll create the new %PATH% String by trimming off the end of %PATH% Else ; the path to remove is NOT in current %PATH% and we can't make any changes If Not $Silent Then ; we'll let User know about error if 's'ilent was NOT specified MsgBox(262160, "Path Removal Error(5)", "The Path specified for removal (below) does not exist in current %PATH%." & @LF & @LF & _ $Path & @LF & @LF & _ "Review command line options before trying again.") EndIf Exit 1 EndIf $RemoveWrite = RegWrite("HKLM\SYSTEM\CurrentControlSet\Control\Session Manager\Environment", "Path", "REG_EXPAND_SZ", $NewRegPath) If Not $RemoveWrite Then ; some sort of error occurred while writing If Not $Silent Then ; we'll let User know about error if 's'ilent was NOT specified MsgBox(262160, "Registry Write Error (6)", "Unable to write removed %PATH% to the registry." & @LF & @LF & _ "Error Code Returned was: " & @error & @LF & @LF & _ "Review command line options before trying again.") EndIf Exit 1 EndIf If Not $Silent Then ; we'll let the User know that all changes have been made as requested. MsgBox(262208, "Path Successfully Removed", "The path (below) was successfully removed from %PATH%." & @LF & @LF & _ $Path) EndIf EnvUpdate() Exit 0 Case Else ; an invalid parameter was entered MsgBox(262160, "Invalid Command option (7)", "Uninstall expects parameters to be as follows:" & @LF & @LF & _ $CommandError) Exit 1EndSwitchUninstall.7z Edited July 6, 201212 yr by Uncle_Gadget
