Hello,
Until now I used DVD’s for my unattended Win7 and softwares. In my WPI v8.2.1 config.js I used the here bellow Command line example to launch the prog installation
cmds[pn]=['"%cdrom%\\Software\\Office2010\\OFFICE14FR.exe"'];
I finished preparing an unattended Win7 and softwares (16 GB) USB key thanks to Rufus utility
What will replace %cdrom%\\Software\\ in the command line to install the progs, since all progs are located into \Software folder of the same USB key as Win7?
I'll appreciate yr help
  • 4 weeks later...
if you still didn't find the answer use %root% that should help
