Posted July 6, 201212 yr Hy Legolash2oI would like to help the developing process with translating the program in hungarian language.Is that possible?Thanks for the replies
July 13, 201212 yr I'm sure there are a couple of us who wouldn't mind doing the translations into our own languages. I'm up for it.There's only a question: would these language files be offered as a separate download (ei "Download Italian Language File and unzip it into your Win Toolkit folder") or would these translations already be in the package and installed in let's say "Languages" folder?However I do think that offering a complete localized Win Toolkit (as in, translate the parts of the code that need to be translated), would just make a download mess. Unless there's English version positioned the way it is and underneath there's a link that throws you onto page with localized Win Toolkit download links.My 0,02€
July 18, 201212 yr Legolash2oWhy are you blocking resources? In order not to change the source code can for example create a file WinToolkit.resources.dll or WinToolkit.resources.ini or WinToolkit.resources.lng for its localization.Example:[string]LNG00002=Auto ShutdownLNG00003=Already running an instance.LNG00004=CancelLNG00005=HideLNG00006=Stand by ComputerLNG00007=Hibernate ComputerLNG00008=Shutdown ComputerLNG00009=Log off WindowsLNG00010=Restart ComputerLNG00011=Shuts down and and turns off the powerLNG00012=%s in %d hour %d min %d secLNG00013=Display InformationLNG00014=Hide InformationLNG00015=Cancel Auto ShutdownLNG00016=Enter your password to stop Auto Shutdown processLNG00017=Invalid password.LNG00018=Start Auto Shutdown ProcessLNG00019=Use this tool to set your computer for log off, stand by, hibernate, or shutdown at a specified time.LNG00020=Select an actionLNG00021=Select a Time LimitLNG00022=HoursLNG00023=MinutesLNG00024=SecondsLNG00025=StartLNG00026=Restart WindowsHow does it work?When you run the new version of the file must be created WinToolkit WinToolkit.resources.dll, which then can be localized without affecting the main program file Edited July 19, 201212 yr by loginvovchyk
July 19, 201212 yr Don't worry i'm just experimenting, if i can make it so my code is protected whilst allowing you to translate it then i will do. Just got to tick the correct boxes when obfuscating it.
July 19, 201212 yr Hmm, i can't seem to find the correct settings, i don't mind sending you an unprotected version, as long as you protect it after.
July 19, 201212 yr Legolash2oThe latest versions (35,36) work fine except for the integration of language pack, Internet Explorer. The program marks the language pack is green when in fact it is not integrated. Maybe you need to integrate the CAB file instead of the MSU file?
July 19, 201212 yr Try in v37 however if you continue getting the problem then make a new thread please.
July 22, 201212 yr Try v42, my 'resources' are unlocked however my code itself is still protected and encrypted.
July 23, 201212 yr Legolash2oVersion 44 works very well! Even WinToolkitRunOnce works in the Russian version!. Well done! :dancing:
July 23, 201212 yr Fixed your post #12 issue, anything else?1. I can not encrypt the localized file, I have failed. I sent you a file by e-mail2. Do not resolved the issue with this setting
July 23, 201212 yr 1. Which email address did you send it to? my hotmail or btinternet one?2. Is that feature already available in Win Toolkit but just not working? You put it in the request forum so i assumed you wanted it to be added and not fixed.
July 23, 201212 yr 1. Which email address did you send it to? my hotmail or btinternet one?sent a email admin@wincert.net
July 23, 201212 yr I guess you ought to tell him, and maybe post somewhere, which email address you prefer people use for which purpose, since you have more than one.Cheers and Regards
July 23, 201212 yr I guess you ought to tell him, and maybe post somewhere, which email address you prefer people use for which purpose, since you have more than one.Cheers and RegardsMy email address is on my profile page.
August 1, 201212 yr I can't because if you remember it failed to protect the code after your translation.
August 2, 201212 yr In case you want it translated in italian, I can do it.Although I'm clueless of what you're doing here with loginvovchyk.
August 9, 201212 yr @LegoLash2owould be possible to activate the language feature? I would have to work with pleasure on a German translation
